Question about 1974-1983 Fiat X-1/9 Antenna, 74-83 Fiat X-1/9 Replacement
Remove center console from 1974 Fiat X1/9
How to remove origianl console for replacement with used console
    Sergeant:
  • 287 Answers
A google search for the haynes manual for your car is in order
Posted on Apr 27, 2014
How to change brake light bulb on a 2014 fiat 500L
https://www.fiatusa.com/download/pdf/manuals/2014-FIAT-500L-OM-1st.pdf
it's in your owners manual page 358 chapter 7
you need a torx 20 screwdriver or bit
Rear Tail, Stop, Backup And Turn Signal Lamps
1. Open the liftgate.
2. Remove the two screws and remove the tail lamp assembly.
3. Remove the four screws (using a T20 driver) and separate the backplate from the lamp housing.
4. Remove the tail, stop, or turn signal bulbs by pushing them slightly and turning counter-clockwise.
5. Remove the backup lamp bulb by pulling straight out.
6. Replace lamps as required and reinstall lamp.
Center High-Mounted Stop Lamp (CHMSL)
This light is an LED assembly. See your authorized stealership
Mar 30, 2015 | Fiat Cars & Trucks
How to remove front strut from a 2006 Fiat scudo van for to replace worn top strut bearing (Thanks for any info)
Link below is for different Fiat model but you could judge whether the same instructions might apply or perhaps answer some more general removal issues
Strut Top Bearing removal Service replacement Front Spring replacement
Dec 01, 2014 | Fiat Cars & Trucks
Centre consol
Fiat Palio 1.2 , Break lights problem
1. checked the fuse - ok
2. checked the bulbs - ok
3. change the break switch - ok
what can be the problem ?
Jan 19, 2014 | 2006 Fiat X1/9
Replacing center console in 2001 tahoe ,, how difficult can I replace with a 2002 console have a 2001 tahoe with a center jump seat style console ,, have located a wrecked 2002 tahoe with a full center...
To replace the console is fairly easy BUT it is time consuming. Assume this is going to take you all day to do.
Remove both front seats. They will possibly be Torx head bolts so you will need a matching socket. Don't use a standard socket as it will chew the bolt head. Disconnect the wiring under the seat for power or heat features. Once the seats are out the middle section should lift free. The dash section is bolted in place to the underside of the dash. Removal is centre first, dash second. Refitting is the other way round.
Mar 04, 2018 | 2001 Chevrolet Tahoe
Looking for the wiring diagram for the power windows in a 1974 model 4.2 Mercedes Benz, with specific detail about the center console switches. Thank you!!!
we have no such diagrams, this detailed info will only be found in a factory service manual, u can try ebay for used one or a manual on a CD to save money, u may also go to www.faxon.com for used factory service manuals
Oct 17, 2010 | Mercedes-Benz 400-Class Cars & Trucks
I have a 1974 buick Apollo with a 2 barrel carb stalling problem
sounds like the idle screw on the linkage is not set correctly.
Jul 11, 2009 | 2006 Fiat 124
My 1974 Buick Apollo has a short circuit in the
Is it a short or a drain on the battery? It's important because a short will blow a fuse and a drain will just deplete the battery.First ck your charging voltage at the battery posts. should be between 13.6 and 14.2 volts. Lower the volts the higher the charging ampereage.. AllOk? , Now remove the ground cable at the battery and put a test ight between the post and cable. The prob on the cable and the clamp lead on the batt post. If there is a drain the test light will come on. Make sure everything is off and the doors are closed.. If you have an alarm system, takte its fuse out temp.. If the lite does not come on, put the alarm fuse back in. If the light comes on, There is your drain. If the battery is properly charged, it should tolerate the alarm.. Good luck
Jun 21, 2009 | 2006 Fiat 124
Where can I buy a replacement AC cord for my Hitachi TV?
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Hitachi 52LDX99B 52" Rear Projection...
1974 fiat 128 alternator
Have you tried International auto parts? They specialize in FIATs. Maybe they can help you or direct you to someone who can.
Here is their website: http://www.international-auto.com/
Jul 06, 2008 | 2006 Fiat 124
1974-1983 Fiat X-1/9 Antenna, 74-83 Fiat X-1/9 Replacement Logo
108 people viewed this question
Top Replacement Antenna Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Replacement Antenna Vehicle Part and Accessory Expert? Answer questions, earn points and help others
