Question about Gli Pro Audio Players & Recorders
Need a new belt
Belt is broken and unable to find another
    Champion:
  • Gli Pro Expert
  • 271 Answers
Hi, we have belts for all models in stock. Cheers John. Stylus City
Posted on Mar 05, 2014
I replaced the belt but as soon as I start the vacuum I smell burning and the belt is broken?
The brush roller is clogged with debris and unable to rotate. Because of this, the new belt was unable to move and the motor shaft spun in one place until it burned through. The brush roller has to be removed and disassembled to allow the end caps to be cleaned inside.
Dec 26, 2016 | Vacuums
The brushes on my Panasonic upright vacuum cleaner are not going around but the belt is
Sounds like one of two things possible. The belt may have stretched and is no longer applying enough tension on the brush or the brush is jammed and unable to turn.
Feb 11, 2015 | Panasonic Vacuums
Power is ON but unable to start program
1) You must have the deck belt is WORN, to due the lack of maintenance , however LUBE the deck belt with 100% of silicone or wax
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.see my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 10, 2012 | Exercise & Fitness
Need a vacuum line diagram for a2003 CTS w/ 3.2L
many of these cars have wires, hoses and other parts running very close to the belt(s), I am unable to find a good diagram for you, but, if you were to look at an area 2-4 inches to the sides of the belt path, you will likely find the broken/ torn vac hose in that area and then run a new hose from that point (keeping in mind that you need to clear the belt path) going back to the port.
also the hose may have just been pulled / blown off the port from back pressure when the accessories that are run by the belt (air pump/ purge) stopped, and it may be laying near the port itself.
Dec 18, 2011 | 2003 Cadillac CTS
The drum does not rotate... it appears the heater is on and it sounds like it is operating normally
Could be the drive belt is broken or worn.
You need to remove the top cover to check the belt.
As you do not state make of dryer, I am unable to give you any further advice.
Dec 25, 2010 | Dryers
My deck belt broke and I am unable to measure it to buy a new one. How many inches is the deck belt for a craftsman 1000?
If you don't have the broken belt, and you don't want to buy 2 or 3 wrong belts. Go to a lawn and garden supply company or sears and buy it by model number of the mower. Then when you have the new one, find the numbers on the belt, and write them down. http://www.searspartsdirect.com or
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Location of No 1 cylinder and direction of rotation
on the shafts you should be able to see little engraved dots rotate shafts to dots meet together this should bring everything to top dead center every shaft make has this tool mark ingraved in them
Dec 06, 2008 | 1995 Toyota Camry
I have a broken drum belt,but I don't see how to put the new one on.I see where it goes,but unable to figure out where and how to start it. Whirlpool LEN2000KQ Electic Dryer
Before replacing the belt, purchase a new idler assembly, the one in there is what caused the belt to fail so soon.
Replacing the belt with one person takes a little practice as you have to hold the drum in place while holding the pulley in the slots on the bottom panel and place the belt over the pulley and attach to motor shaft. The diagram shows how the belt is routed:
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Whirlpool Dryers
Top Gli Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gli Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
