Question about Pelouze Ps20dl 20 Internet Ready Postal Scale
Tare is not 0
Is there a way to re calibrate this scale so it always in 0 when you are going to weigh something?
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
How do I change my 100 gram weigh max scale from calibrating at 50 grams back to 100 grams?
a scale is calibrated at half it's capacity. when you use a 50 gram weight to calibrate it, it can still measure 0-100 grams properly.
Aug 15, 2014 | Measuring Tools & Sensors
Need to know how to adjust tone arm and anti-skate
Get one of those little mini-digital scales that should sell for about $30 or less. Make sure it reads in 0.1 or 0.01 increments. Unplug the turntable (so the platter doesn't spin) and place the scale in the tonearm path. Most tonearm and headshell combos should work well in the 1.0 to 1.5 g range. Weigh the tonearm balancing on the scale about midway through the path (where it would be in the center of the record)
I used a flat plastic credit size card to protect the stylus on the surface. Don't forget to tare the scale to 0. Attempt to calibrate your weight scale adjustment on the tonearm to match the scale while you are at this. Once you have found a setting that works for you, match that marking on the weight scale adjustment on the anti-skate wheel.
You should have a turntable that sounds nice and is also gentle on your records!
Feb 18, 2013 | Audio Players & Recorders
Starts up beeps put somehing on it and it dosn't weigh
The pressure sensor under the platform is probably corroded or broken...it may not be economic to replace it...buy a new scale.
Jan 13, 2013 | Royal Postal Scale Gray
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
Need instruction manual. When weighing a container....how to set the weight so you do not have to subtract container weight
You have provided very little information and your question ended up in the vacuum cleaners category. I know your question is related to a scale so I will take a stab at a solution. If there is a "Tare" button, put your container on the scal and press the tare button, you should now see zero for the container and the scale will begin measuring the weight when you add something to the container.
Jun 27, 2011 | Vacuums
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Sep 08, 2009 | Health & Beauty
Pelouze Ps20dl 20 Internet Ready Postal Scale Logo
18 people viewed this question
Top Pelouze Office Equipment & Supplies Experts
k24674
Are you a Pelouze Office Equipment and Supply Expert? Answer questions, earn points and help others
