Question about Fujifilm Instax Mini 50S Instant Print Camera Piano Black 16102240
My instant camera won't open
I tried pressing the power button, but the camera won't turn on
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
IPhone camera won't open
Try restarting your phone by doing a full reboot. Hold down the power button and the button on the front for about 8 seconds. then slide to power off. Once that's done, restart your phone by pressing the power button. If that doesn't work do a full restore of your phone via iTunes.
Mar 15, 2013 | Apple iPhone 3G
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
My lcd display won't show the camera image while taking pics but it will show the menu and previously taken photos by pressing the play button. What could be wrong?
Turn the camera on, and press the DISP button on the back of the camera. This turns the LCD screen on and off. The idea of this button is to save battery power (you would then use the peep hole optical viewfinder in its place).
Dec 14, 2012 | Canon PowerShot SX30 IS Digital Camera
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
When i turn on the camera the screen is pitch black but i can still take a picture but nothing shows up the lens is open and clean. wat do i do?
Could be a couple of things.
Hopefully, you accidentally configured the camera to not provide an instant review.
To set the instant review time:
In Capture mode, Press the menu button
use the 4-way controller (up/down arrows) to select [instant review]
press the 4-way controller (right arrow)
Use the 4-way controller (up/down arrows) to change the display time
press the OK button.
Press the menu button to return to capture status.
Mar 10, 2011 | Pentax Optio E20 Digital Camera
Can't unlock phone I forgot my motoblur passcode and my lock code
You need to perform a hard reset on the phone. Follow these directions:
hese steps will wipe all data from the device.
1. Power off the phone. If the phone is frozen and won’t turn off using the Power button, pull the battery out.
2. With the device off, press and hold the Power andCamera buttons.
3. Release the Camera button when prompted to do so.
4. Press and hold the Volume Down button until a yellow exclamation mark appears on the screen.
5. Open the physical keyboard and press ALT + L, then press ALT + W to complete the hard reset of the Cliq.
That should do it! Good luck!!
Aug 10, 2010 | Motorola Mobility CLIQ Cell Phone
Sony Cybershot S40 has white screen.still sounds like picture is being taken, reviewed, etc...is there anything I can do thanks
This sounds incredibly stupid but it instantly works- I had this problem with both of my daughter's camera (same model number)
On the front of the camera, to the right of the lense and under the flash, it says "Cyber-shot". Press that spot really hard/punch it. The LCD should return instantly.
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Fujifilm Instax Mini 50S Instant Print Camera Piano Black 16102240 Logo
77 people viewed this question
Top Fuji Photography Experts
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
