Question about Samsung 37" 1080p 60Hz LCD HDTV LN37D550K1F
Cannot remove from base
Trying to move the tv to a wall mount from the base, it is stuck in there even after when we took screws out. Samsun 29 inch LN37D550K1F
  • 4 Answers
SOURCE: My wall studs are wider than my television mount
It is very unusual to have wall studs this far apart - most are 16" on center. Mounting anything that is very heavy on studs so far apart will not be safe. Have you considered a table top stand?
Posted on Dec 28, 2008
  • 718 Answers
SOURCE: How can I put the base back on my tv Sony Bravia KDL40S2000
Lay the TV face down on a flat surface covered with a cloth. Back out all the screws holding the base stand. Hold the back and front against the base shank while tightening all the screws through the base. Make sure they are tight.
Posted on Mar 10, 2009
SOURCE: Wall mounting tv. How do I get the base Off?
There is a metal part that the TV sits on. To remove base you need to remove I believe it was 4 screws center lower back of TV, then pull off base. Hope this helps.
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: how do you take the base off the tv for wall
have you found out yet? cos im trying to do this too. the base comes off cos i put it on, but theres a leg that wont.
Posted on Nov 02, 2009
SOURCE: how to remove base on samsung 2333hd
We had the same problem, we just wiggled it back and forth, gave it a good tug, and hey presto! We got it out. I'm not sure whether this is the "official" method of doing it, as nothing is mentioned in the instruction manuals.
Posted on Jun 07, 2010
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
How to disengage the stand from an LG 42PC5D
There are two pegs that protrude from the base into the tv.......there will be two large philips screws on each. remove and pull strait up off the base........hope this helps!
Jun 06, 2010 | LG 42PC5DC 42 in. Plasma HDTV
Philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Dec 26, 2009 | Philips 42PFL3704D LCD TV
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Nov 23, 2008 | Toshiba Televison & Video
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Feb 24, 2008 | Televison & Video
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Nov 24, 2007 | Televison & Video
Samsung 37" 1080p 60Hz LCD HDTV LN37D550K1F Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
