Question about Sony Bravia DAV-HDX265 Theater System
No sound from speakers
Put tv/video on and i get no sound
Have sound no picture in tv mode and dvd.
Hello from Venezuela, it's possible that speaker is bad, open the tv and find a tester, wiht the tester in beep continuity test mode and the tv off, put in the speaker terminals the pins off tester respectibly, in the tester screen must view something like this: 7.95 to 8.20 or 3.80 to 4.10. And must hear a beep sound from tester, it means the speaker is ok.
If not, the built in sound amplier is provably bad and you must change the aplifier IC with a experience o certified thecnician...
About the video could be a fail in the audio video mixer of tv try replaceit....
Att: Eduard.
May 23, 2015 | Audiovox VE1020 10.2 in. TV/DVD Combo
How do i hook up craig surround sound mode cht904
Are you using your TV for both Audio and video? Sounds like you are only wanting HD video and SS audio. If, so only send HD video signal to TV and keep SS Audio direct to speakers from SS receiver/ amp.
Jan 01, 2015 | LG Audio Players & Recorders
Aux won't work to tv
The TV should have two sets of AUXilliary ports. Audio In and Audio Out. Video IN and Video Out.
On TV plug in OUT, on the other device should be plugged in IN.
Nov 29, 2013 | Audio Players & Recorders
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
LG50PQ30
in menu speakers switched on or off?
if you put your ear to the speaker do you hear anything?
Is set connected to box of some kind for audio and video signal?
Mar 13, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Hi I've connected the game to the T.V. it works, but when I connect the system through my surround sound system I get only sound coming through the speakers and no video.
is the surround sound connected to the tv video input? if so, did you put your tv on the right video/ input setting that the surround sound is on?
May 04, 2011 | Nintendo Wii Console
Cant get sound from tv on speakers.
lost remote and cant get sound from ks3102
Dec 16, 2009 | Koss KS3102 System
Want to connect laptop to tv
The specifications on your computer suggest that it has an S-Video port, which can be used to connect it to a TV; provided the tv has an S-Video input port on it.
Additionally, this will put a picture on your TV, but sound will have to come from somewhere as well. Most laptops have sound and speakers built in, but if you are watching TV, you will never be happy with that sound.
I have run a speaker connection from the outputs on the laptop to the outputs on the TV with success. When I did this, I used the video/sound cable that came with my video camera. It had a stereo male plug at one end that fit into the laptop and the other had two RCA plugs, one yellow and one red.
Typically, the yellow is for video, and red and white are for sound. In this case, I used the yellow for sound and it worked out fine.
All this information is based on the premise that your TV will support this connection. If not, you may be able to connect to a VCR (remember those things?) and run it that way.
good luck.
tony
May 18, 2009 | Computers & Internet
No sound on PLTV 4250
Easy! If you have a VCR,put a VHS tape in the VCR,run the video cable behind the TV and the audio cable from the VCR to a hi fi receiver/speaker(cd input or tape input.)
If you have sound coming out from the HI FI,go ahead and plug the audio connection along with the video connection behind the tv.If there is no sound, it could be:
A. your TV speaker is completed its mission-;o)Blown speaker.
B. you are on TV MUTE!
C. your audio cable is defective(small chance,cause you have left and right!)
D. your connection was incorrect.
solutiondoct
Oct 13, 2008 | Protron PLTV-4250 42 in. LCD Television
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Sony Bravia DAV-HDX265 Theater System Logo
24 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
