Question about Car Audio & Video
Video showing how to install a new solenoid on a 1995 Ford F 150 Flare side v8 engine automatic transmission
I have a 1995 Ford F 150 Flare side 8 cylinders dual gas tanks. It was cranking and running fine, but then all of a sudden it wouldn't crank at all, we used the screwdriver test and it cranked, so we bought a new solenoid and installed it . Only now the lights and stereo will come on, but I dont think we have it wired back right, and we didn't take a picture of where all the wires go. Also someone before us installed an Alpine stereo in the truck, so I'm sure some of those wires go to the stereo, but we don't even know where the starter is located. So as you can see we are not mechanics. LOL
  • 21 Answers
SOURCE: 2002 Grand Am 3.4L automatic.
Need to know which option you have? L61 or LA1 Will e-mail you electrical diagram
Posted on Jul 19, 2008
  • 50 Answers
SOURCE: '98 s-10 won't crank and run
bad conection on starter solonid tray diferent starter or solonoid
Posted on Mar 13, 2009
  • 87 Answers
SOURCE: how to install into my 1993 ford probe?
Here are the factory wiring colors match these to the aftermarket names (12v to 12v Ign - Ign, etc)
1993 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
Posted on Jun 02, 2009
  • 2226 Answers
SOURCE: how to fix a 821 EONON car stereo
you could just try disconnecting power overnight and see if it resets then. sometimes pushing reset doesn't always completely clear the memory.
Posted on Jun 03, 2009
  • 948 Answers
SOURCE: 1986 Suzuki GS 450 won't start
Take the carburetors apart and either rebuild them or clean them thoroughly.
Posted on Jun 19, 2009
I have a 1995 Ford Taurus 3.0 engine automatic transmission and it starts fine then stalls when you give it gas what could be the problem
Hi Anonymous, The link below is a short YouTube video showing how to test and fix a car that shuts off randomly, Also there's videos down the right side of the link that might be worth looking at as well, Hope this helps.....CHEERS..
Fixing Car That Shuts Off Randomly
Apr 29, 2016 | Ford Cars & Trucks
I have a Ford F 150 2007 v8 it needs a automatic transmission will a 2005 Ford F 150 transmission be compatible
I wouldn't be installing a used trans,
if that is why your asking
Rebuild yours
No reason to need a trans on a 7 to 8 year old vehicle
I would guess you never change the fluid every 2 to 3 years
Most Ford Transmissions have known problems, brand new,
& they are well know by the shops that rebuild them
So get it rebuilt & do all the updates or suffer the same fate
every 70 to 100,000 miles
You would have to ask a trans shop or have a dealer run some
number off the unit, to answer that
If you see different wiring, etc, then,no,unless it can be switched
over to the 2005 unit.
Is the other trans from the same motor & same type vehicle
These things are all computer controlled,you can't just assume
you can mix & match from one year to the next
Nov 02, 2014 | Cars & Trucks
Firing order diagram for 2008 f 150 4.6 v8
1 - 3 - 7 - 2 - 6 - 5 - 4 - 8
It has the Coil On Plug ( C.O.P. ) ignition system with ( 8 ) individual coils
The engine cylinder locations are numbered :
4 - 8
3 - 7
2 - 6
1 - 5
front of Ford F-150 ( V8 )
Jun 27, 2014 | 1984 Buick Regal
1995 t-bird v8. Starter will not crank, clicking noise coming from possible relay behind right headlamp. Battery is good and lights are bright no dimming when key is turned
The Ford V-8 they use in both Crown Vic and T-Bird are good for losing the solenoid to the starter. Replace that first before looking for a new starter.
Apr 17, 2012 | Ford Cars & Trucks
How to find codes for check engine light on
Check Engine Light Codes and Meanings
Long blinks Short blinks Problem
1 1 Camshaft position sensor
1 2 Mass air flow sensor
1 3 Engine coolant temperature sensor
1 4 Speed sensor
1 11 EVAP control system (flow)
1 14 Fuel injection system right bank (too rich)
1 15 Fuel injection system right bank (too lean)
2 1 Ignition circuit
2 3 Closed throttle position switch
2 5 Idle speed control
2 9 Fuel Injection system left bank (too rich)
2 10 Fuel Injection system left bank (too lean)
3 1 ECU
3 2 Exhaust gas recirculation system flow problem
3 3 Front left O2 sensor
3 4 Knock sensor
3 5 Exhaust gas recirculation temperature sensor
3 6 EGRC-BPT valve
3 7 Closed loop control
3 8 Closed loop control
4 1 Air intake temperature sensor
4 2 Fuel tank temperature sensor
4 3 Throttle position sensor
4 7 Crankshaft position sensor
5 3 Front right O2 sensor
5 4 Automatic transmission control unit
6 3 Cylinder #6 misfire
6 4 Cylinder #5 misfire
6 5 Cylinder #4 misfire
6 6 Cylinder #3 misfire
6 7 Cylinder #2 misfire
6 8 Cylinder #1 misfire
7 1 Multiple cylinder misfire
7 2 Three way catalytic converter (right side)
7 3 Three way catalytic converter (left side)
7 4 Evaporative emission control system pressure sensor
7 5 Evaporative emission control system
7 7 Rear O2 sensor
8 1 Vacuum cut valve bypass valve
8 2 Crank position sensor
8 3 Absolute pressure sensor
8 4 Automatic transmission control unit
8 6 Evaporative emission canister purge control solenoid valve
8 7 Evaporative emission Canister purge control solenoid valve circuit
9 1 Front Right O2 sensor
9 3 Evaporative emission Canister vent control valve
9 5 Crankshaft position sensor
9 8 Engine coolant temperature sensor
10 1 Front left O2 sensor
10 3 Park and Neutral position switch
10 5 EGRC solenoid valve
10 8 Evaporative emission canister purge volume control valve
11 1 Inhibitor switch
11 2 Revolution sensor
11 3 Improper shifting to first gear (Automatic transmission)
11 4 Improper shifting to second gear (Automatic transmission)
11 5 Improper shifting to third gear (Automatic transmission)
11 6 Improper shifting to fourth gear (Automatic transmission)
11 7 Solenoid valve lock up function
12 1 Shift solenoid B (Automatic transmission)
12 3 Overrun clutch solenoid valve (Automatic transmission)
12 4 Torque converter clutch solenoid valve (Automatic transmission)
12 5 Line pressure solenoid valve (Automatic transmission)
12 6 Throttle position sensor (Automatic transmission)
12 7 Engine speed signal
12 8 Fluid temperature sensor
13 2 MAP/BARO Switch Solenoid Valve
13 5 Fuel pump control module
13 8 Cooling fan
Dec 12, 2011 | 1995 Nissan Maxima
What does this code mean p0775 and p0735 lincoln v8 2002
P0775 FORD - Automatic Transmission Pressure Control Solenoid B Malfunction Possible causes - Faulty line pressure solenoid B valve
- Line pressure solenoid B valve harness or connectors
- Line pressure solenoid B valve circuit is open or shorted
- Low transmission fluid level
- Dirty transmission Fluid P0735 FORD - Automatic Transmission Incorrect Fifth Gear Ratio Possible causes - Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
May 27, 2011 | Lincoln LS Cars & Trucks
Where is transmission dipstick on 1995 ford f150
it should be on the left of the engine with a yellow handle
Apr 21, 2010 | 1995 Ford F150 Styleside Regular Cab
Will the six cylinder auto work behind the V8? We are talking ED.
yes a transmission should bolt up to the v8 as long as it's stays a small block and not a big block , i'm sure the tranny bolt pattern will bolt on a small block or a v6 /but the v6 transmission wont last long on a v8 :) gl on your project..
Jan 06, 2009 | Ford Fairmont Cars & Trucks
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
