Question about HP Photosmart C6380 All-In-One InkJet Printer
Mechanism Error: The print cartridge cradle cannot move. Turn the printer off, free the cartridge cradle, and turn the printer back on. What can I do to solve this problem???????
2 Suggested Answers
  • 289 Answers
SOURCE: Hi, my HP Deskjet F380
when you open the cover of the printer where is the cradle located? if it is in the right push it to the left corner,then plug the unit observe, if still not work check if it is on the left push it to the right, be sure to unplug first the unit before executing this method, then on again the unit
Posted on Aug 07, 2011
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Hi, my HP Deskjet F380 wont printi. Ths error message comes up : "Mechanism Error: The print cartridge cradle cannot move. Turn the printer off, free the cartridge cradle, and turn the printer back...
Aug 07, 2011 | HP DeskJet F380 All-In-One Printer
How do i change the ink cartridge on my printer
These are the steps on how to install/replace cartridge(s) on Hp Deskjet 5550.
  • Press the POWER button to turn on the printer.
  • Open the top cover. The cradle moves to the center of the printer.
  • Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts of the print cartridge meet the copper contacts of the print cartridge cradle.
  • Close the cradle latch.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 19, 2010 | HP DeskJet 5550 InkJet Printer
The print cartridge cradle cannot move - hp 5652 after slight service
This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON.
Regards,
JR
Oct 08, 2010 | Office Equipment & Supplies
I get the alert "no printer cartridge" when there is a cartridge
  1. Open the printer top access door. The printer carriage will move to the center.
  2. Remove the USB cable from the back of the printer.
Remove the print cartridges from the printer.
  • Unplug the power cord. (Do not press the Power button to turn off the printer.)
  • Verify that the correct cartridge is being used for the printer. Cartridge reference can be found in the User Guide.
  • Verify that the protective plastic tape has been removed from the print cartridge
  • Locate the copper circuit strip on the back of the cartridge.
  • Clean the copper circuit strip with a dry foam-rubber swab or a lint-free cloth.
  • Reconnect the power cord to the printer.
  • Turn on the printer if it does not turn on automatically.
  • Insert the print cartridge into the cradle at a slight upward angle until a resistance is fallen. Firmly push the print cartridge into the cradle. A snapping sound will be heard when the print cartridge is correctly positioned. The print cartridge fits securely in its cradle.
  • Close the top access door. The printer carriage should move to the left.
  • If the printer light is on steady, perform a self test report as follows:
    1. Press and hold the Power button, and then open and close the top cover four times.
    2. Release the Power button.
  • If the printer light continues to blink, replace the print cartridge or cartridges one at a time
  • Print cartridge recognition error messages are displayed if the printer is unable to communicate with the cartridge(s). A faulty cartridge or dirty contacts on the cartridge may cause this.
    Feb 06, 2010 | HP LaserJet 3330 All-In-One Printer
    Hp 812c cartridge cradle is stuck on the right, not moving to the
    unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
    Feb 27, 2009 | HP DeskJet 812c InkJet Printer
    Even thought there is NO paper jam, I still get an error message:
    Please try this solution :
    1. Turn the printer off and open the access cover.
    2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    3. Turn the printer on, load some paper, and press the Form Feed button.
    4. Watch the paper as it feeds through and try to determine where the jam is occurring.
    5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    7. Turn the printer off.
    8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    Feb 19, 2009 | HP DeskJet F4280 All In One Printer InkJet
    Will not print
    Try moving the cartridges with the power cord unplugged. Your problem sounds fatal.
    Jan 16, 2009 | HP DeskJet 6840 InkJet Printer
    Change ink cartridge
    Here is the procedure to change the ink cartridge
    • First Press the POWER button to turn on the printer.
    • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
    • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
    • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
    good luck:-)
    Oct 08, 2008 | HP Office Equipment & Supplies
    Print cartridge cradle is stuck ican't find where it is jammed
    This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
    Apr 16, 2008 | HP Office Equipment & Supplies
    HP Photosmart C6380 All-In-One InkJet Printer Logo
    43 people viewed this question
    Seeker5211
    Seeker5211
