DELL 17'' CRT Color Monitor Screen slight tilt
    Genius:
  • 1,552 Answers
Still using a CRT? For less than $30, you can buy a "pre-owned" 17-inch LCD screen, and get better image-quality without any "tilt".
Posted on Apr 19, 2014
4 Suggested Answers
  • 75 Answers
SOURCE: Dispaly settings for samsung 794 MG 17" CRT
can u send me the wat is in the setting menu of your monitor?
Posted on Mar 12, 2008
Matampong
  • 153 Answers
SOURCE: 17 crt monitor (BOKA)turned to green resolution
Try moving the VGA cord to the PC, faulty VGA cord displays such color problem.
Posted on Nov 27, 2008
  • 10 Answers
SOURCE: LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Posted on Dec 10, 2010
Hcl crt color 15" digital monitor.red color is
Unfortunately, this is not a fixable problem. Samsung CRT monitors are well known for losing color; they have defective cathode ray tubes. I recommend that you buy an lcd screen. sorry if that wasn't what you wanted to hear! don't forget to rate
Jan 13, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
Whenever I start my computer after a few hours, the monitor starts with a dark color even the letters appear slightly hazy as if the monitor is decades old.Please help.
Try to degause it will be under the monitor settings. How old is this monitor. It's a CRT monitor and that is the way they fail typically.
May 22, 2010 | LG Studioworks 700S 17" CRT Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
Slightly out of focus. Is there an (internal) adjustment, and if so, where?
over time the shadow mask picks up a magnetic charge that interferes with the focus of the electron beams which makes the image look fuzzy or out of focus...to fix this.. most monitors have a deguassing coil/button..look for a DEGAUSS button or in the menu selection on the monitor..Degaussing usually makes a "thunk" sound and the screen will go crazy for a moment ..
May 06, 2009 | Computers & Internet
Out of scn range
Hi
Click StartGo SettingsControl Panel  Display Settings your screen 1024*768 select  it and 32 bit color quality also.. apply it ok..
it will work.
Nov 18, 2008 | Dell P780 17" CRT Monitor
MONITOR SCREEN KEEPS BLANKING OUT WITH A ORANGE COLOR OR BLUE COLOR
It is one coulour missing and it can b mostly due to CRT socket loose or some dry solder in CRT {RGB) path..
Chck out...
This is a technical freak from INDIA!
Apr 07, 2008 | Compaq fs740 17" CRT Monitor
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
Problem with my Dell E771mm 17 in.CRT monitor
How far from the sides is the image? If it?s just an inch or two you can use the monitor adjustments to expand the image to the edge of the screen where it was previously. If its too far in then the only option is to have it repaired. You didn't mention where you are but in the US even a minor monitor repair that involves at tech opening the monitor is going to cost at least $45, perhaps more. That?s a lot of money for a monitor worth about $100 new so a new or used monitor may be a more cost effective option for you. Let us know if you have any other questions and please don't forget to rate this post.
Apr 04, 2007 | Dell E771p 17" CRT Monitor
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
