The tv screen is moved up 2inches. the top is off the picture and the bottom is showing black. is there an adjustment?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check picture settings. Refer its user manual for details. Reset the TV to its factory settings. Gopakumar Gopalan Google
Posted on Feb 15, 2014
How to fix horizontal lines on LG TV
Not sure if this is recent but in settings adjust picture size to fit. Top to bottom side to side.
sounds like you are seeing what are called retrace lines
Sep 30, 2016 | LG 50" 5700 Series LED HDTV - 50LN5700
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
TV picture has moved up
your pic. has shiffted vertically. very easy to fix. open the tv set, located the crt tube(end of the screen) there are four wires going down to the board that is compined in one socet. around that socet, you will find small knobs, look for vertical phase and you could adjust that pic. the adjusting should be done while the tv is on and has pic so be careful, you are dealing with a live electricity. good luck
Feb 28, 2007 | Beko 324250WN 28" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
