Question about Frigidaire Affinity ATF7000E Front Load Washer
My affinity washer does not fill on any cycle but bulky and now that is not working either.
Two days ago my washer worked fine. Yesterday it did not fill on any cycle but the bulky cycle and now this morning it will not fill on that cycle either. Also the time said 1:20 for the bulky cycle and it ran through that in about 5 mins. Any help is appreciated
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: my Frigidaire affinity front load washer will not fill with water on bulky,heavy and normal wash modes but works fine on delicate setting
What is the model number of your unit?
Posted on Nov 01, 2012
richroth
  • 9472 Answers
SOURCE: Frigidaire Affinity Washer not emptying completely.
Check to be sure the drain filter is clear.
Posted on Dec 05, 2012
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
The washer is stopping during the rinse cycle.
Does it flood the room as it continues filling? If not maybe the outlet house isn't high enough - it need to rise up at least a couple of feet to prevent the water from syphoning out as fast as it goes in.
If the water is going in but only slowly, check the water valves in the line to the machine, and also the inlet filter gauze, to make sure they are not clogged.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 12, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Whirlpool Duet Washer beeps and will not allow temp change
Norma,
It's likely that this is a control board issue. Luckily you are still within your warranty period. I'd recommend contacting Whirlpool about this.
You may also try "re-booting" the CPU by unplugging the washer for a few minutes then plugging it back in.
Jun 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
