Question about Cobra 18 WX ST 40-Channels Base CB Radio
WHY DISPLAY SHOW 88 ?
THE TX METER INDICATES A STRONG SIGNAL BUT THE CHANNEL DISPLAY WINDOW WILL ONLY SHOW 88
    Genius:
  • Cobra Master
  • 1,795 Answers
You have to have that led replaced by a tech
Posted on Aug 23, 2014
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
88 is displayed in the chanel window
its going to cost you more to fix this problem than the radio is worth.Spend the money on a new radio.
Feb 02, 2014 | Cobra 18 WX ST II 40-Channels Base CB...
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
Behringer SX3242FX intermittently looses signal to the left main. When it's out, the the level meter indicates signal on the left, but not the right. This is consistent in both mono and stereo inputs....
Make sure you are using BALANCED cables from this... eithe XLR or TRS cables. Using TS unbalnced cables MAY ground out the signal which is sent as balanced. Here is a schematic for the 24 channel unit... yours just has eight more channels. http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
By looking at the signal paths, you can OFTEN do a lot of testing from the available jacks. If the contacts on the right main INSERT jack go bad, that would cause your problem,,, NEVER use other than an insert cable in these jacks.
Sep 24, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
Our new digital LCD tv occasionally suffers from picture breaking up and even total loss of signal, after some time, 5 to 15 minutes the signal is restored. Fiddling with the aerial run and connections has...
Tune to a strong channel.
Go into the menu. Find the Channel or Antenna whatever your tv calls it. Set the signal strength display.
If the signal strength show good and your picture is lost then a problem may be in the tv.
More than likely the antenna is not picking up a strong signal. Try rotating it some.
You can go to www.tvfool.com to see what stations are in your reception area.
Feb 13, 2011 | Televison & Video
Ferguson DV3 set-top box not finding BBC channels
I have solved the problem by selecting Manual Tune in the Menu. This means selecting each channel one at a time beginning at 21. The indicator shows the Signal Strength and Quality for each channel. If both show a green bar (strong on both counts) give it time to identify the new programs on each channel and add them. It will show how many found and added if you wait a few minutes. When each channel is done, move on to the next one. The last channel is 65 I believe but there is not much up the top end.
When I had finished going through this routine I found it had indeed added all channels I needed including BBC1 and BBC2
Aug 21, 2009 | Televison & Video
Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
Nov 15, 2008 | Westinghouse TX-42F430S Television
URL prolbems
Have you tried pressing the reset button?
Apr 27, 2008 | Palm TX Handheld
Cobra 18 WX ST 40-Channels Base CB Radio Logo
63 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
