Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Grill(s) not working
Our oven has a dual grill in the top and it was in storage for a long time. Upon retrieving it I noted the switch/thermostats for the main oven and grills had been knocked and needed replacing. I did this and the oven works again, but the grills did not - so I replaced the elements thinking that was all that could be at fault. But alas neither grill will work and the light does not come on at the front panel either. I rewired the switch as per instructions supplied with it (EGO switch replacing the old one) as you have to piggyback two connections. Did I get it wrong or is there a fuse or something else that could be at fault?
3 Suggested Answers
SOURCE: Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Posted on Feb 07, 2010
  • 1015 Answers
SOURCE: My grill is not working. What could be the
The first thing you will need to do is try lighting the burner manually with a match or bbq lighter. Bring the flame next to the burner then turn on the griddle knob. It should light up. If it does then it is either a weak spark on the ignition system due to debris on the electrode or there is blockage in the burner eyes at the electrode. Try poking out the eyes of the burner with a safety pin or sewing needle. And try using a wire brush to lightly clean the electrode head(where the spark comes from). If your tried lighting the burner with a match or bbq lighter and it did not light or a very small flame came out then there is a restriction in either the burner eyes, venturri, or burner orfice. Frist inspect the burner eyes for any blockage(grease or particles of food) and then use the sewing needle or safety pin to clean out all the burner eyes. If the burner is easily removed then go ahead and remove it and check the venturri(burner pipe) for any debris inside it. A small bottle brush can be used to clear the venturri. And finally with the burner removed you should be able to see the burner orfice. It will look like a small nut(usually brass) with a very small hole in it. This is where the gas comes out and if this hole becomes plugged then the burner will not work. The best way to clear this hole is to use a very small wire like the wire on a sandwich bag tie strap. Burn the plastic off of the tie strap to expose the thin metal wire and then use the wire to clear out the hole. DO NOT USE ANYTHING LARGE to try and clear out this hole. It is tiny for a reason and the soft brass can be opened up easily while try to clear the orfice hole causing a huge increase in gas pressure. If you clear the orfice hole and still do not get any gas pressure then the next step would be to remove the orfice(this requires a orfice wrench) and verify that you get gas coming from the burner tube with the orfice removed. If you do not get any gas after removing the orfice the more than likely the problem lies with the burner valve restricted internally and will need to be re-built or replaced.
Posted on Apr 24, 2010
Grill turns on when cooker is turned from the isolater,
I assume you mean if the main electrical isolation is switched to on , the grill/ upper oven heats up even though the grill / upper oven switch is correctly set to off ......if this is the case you require a replacement thermostat for the upper oven I believe these are now obsolete and the alternative comes as a kit part no. 012959401 to modify the wiring replace both upper and lower oven thermostats see instructions attachedcid:eb5fa66b-5b72-4dad-aafc-a1f3a691fb03
Jul 03, 2014 | Stoves 800DFDOm Dual Fuel (Electric and...
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Grill is not working
Is The small amount of heat you are getting coming from the bottom element in the top oven or is half the top Grill element working.To start with you have a double grill element and either the whole element has gone or just half the element.This is controlled by a selector switch which could be at fault or the Thermostat that controls the temperature.
Hope this helps.
Jul 07, 2010 | Electrolux Insight EKC6049X Stainless...
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
