Question about Bizfon BIZTouch 3 Corded Phone
How do i change the date and time on a biztouch3 phone?
My BizTouch3s have not dial tones.
They need to be plugged in to work. Check the pbx.
Feb 04, 2015 | Bizfon BIZTouch 3 Corded Phone
How do i change the time and date?
In Idle mode, press Menu ? Settings ? Phone Settings ? Time & Date.
You should be able to change the time and date manually from there.
Nov 10, 2014 | Samsung SGH t340G Straight Talk Cellular...
How do I change the time on Pantech Swift?
Setting the time & date
1. Tap Menu; > Settings > Phone.
2. Tap Time & Date.
3. Change Time, Time Format, Date, Date Format or Auto Update > Save.
Mar 10, 2013 | Pantech Swift Mobile Phone - Purple at&t
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
The time and date are programmed through system programming. A 4015 phone cannot do this programming. A 4150 phone setup as a subattendant phone with the "attendant setup time/date" class of service option enabled for the 4150's class of service can change the system time and date. This is accessed through the LCD touch screen keys of the 4150. Scroll through the options in the screen until you find set time /date.
Also an attendant console with the "attendant setup time/date" class of service option enabled for its class of service can change the time and date. Press the function button then choose attendant function.
Choose set time. Enter the time in four digits as in 0800 for 8:00. Choose PM if needed. Choose set.
Choose exit to finish.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
Setting time and date on Nokia cell phone
To change the clock settings, press adnanbhatti_4.png and select Applications > Clock > Options > Settings.
To change the time or date, select Time or Date.
To allow the mobile phone network to update the time, date, and time zone information to your device (network service), select Network operator time > Auto-update.
SOURCE
Nov 27, 2010 | Nokia N73 Cellular Phone
Cannot change date
Go to "Settings", then Option 4 ("Time and date"). Make sure the 'Time zone updating" option is set to either "Prompt first" or "Manual only" (NOT "Automatic"). Then try changing the date.
Apr 16, 2009 | Samsung SGH-G600 Cellular Phone
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
CHANGE THE TIME/DATE AND TURN THE RINGER ON
You have to use the feature 9 # from the administrators phone (usually extension 100)
Go to extension 100, press "feature,9,#" and you'll see the numbers on your display blinking like a digital alarm clock. Enter the time and then press feature to complete.
Oct 11, 2007 | NEC DTU 8D-2 Corded Phone
Bizfon BIZTouch 3 Corded Phone Logo
44 people viewed this question
Top Bizfon Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bizfon Lands Phone Expert? Answer questions, earn points and help others
