Question about Black & Decker B2300 Bread Machine
How do i get the dough settings to work?
I cannot seem to get the dough setting to turn on.
2 Suggested Answers
  • 433 Answers
SOURCE: first time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
Posted on May 13, 2010
How do I put a delay start in the dough setting on a B&D B6000c bread maker
You can not in any machine use a timer delay on the dough setting. Sorry.
Feb 18, 2015 | Kitchen Appliances - Others
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Dec 08, 2014 | Kitchen Appliances - Others
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Pasta roller squeaks when dough is not going through
The others had good solutions but I thought I would add mine as well.
I put vegetable oil on both outer edges of a folded paper towel that fits the entire width in the narrower roller settings of the machine. I run it through 3-4 times as if it were a piece of dough. It takes away the squeaking.....at least until it is needed again.
Dec 30, 2010 | KitchenAid Pasta Roller / Cutter Set
First time use. set machine to dough and pressed
May 12, 2010 | Black & Decker B2250 Bread Machine
When you want to make only dough the dough senting does not work
The dough setting has a 20 minute delay before the paddles start to move. The manual say's "for most programs, there will be a 15-minute delay before mixing cycle begins"
Nov 07, 2009 | Black & Decker B2300 Bread Machine
Why my dough is tearing when i try to make ravioili?
You have to let the dough rest about 30 min. to 1 hour before passing the pasta in the roller. Also if you put some flour on both side of your pasta for the first passing through the machine it works well.
Jul 21, 2009 | CucinaPro Cucina Pro 150-25 Pasta Ravioli...
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
Bread comes out hard, dense, lump
I had a similar concern with a different breadmaker. Finally gave up and settled for a different setting and it seems to mix, and rise fine but have to settle for a different texture/hardness for the crust. I can only guess some computer chip has failed in that setting!
Mar 13, 2009 | Toastmaster 1183N Bread Maker
Black & Decker B2300 Bread Machine Logo
66 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
