Question about Pool & Spa
How ahould i set my timer on my 110volt spa? - Pool & Spa
    Problem Solver:
  • 6 Answers
It should run at least 4 hours in every twelve. (eight hours total daily)
Posted on Apr 04, 2014
The timer works but after starting within a few min the motor speed goes to low speed and stays there
well I cant be absolute sure because you didn't include the make and model of the timer/control , but I can say on most automatic controllers for pool and spa pumps , if you set them to come on automatically at a preset time of day most will run in there slow to mid speed , this is because the filter doesn't need to have highest flow to work , and then this reserves the highest speed for when it's needed like when pool/spa is in use by people and the control should allow an operator to manually override it to full speed as well , hence the automatic cycle time of day should not be set to operate at peak use times but instead late at night or off use hours (saves energy too)
Aug 15, 2015 | Pool & Spa
How do you set up the timer for heating a ampac pulsar series spa?
http://waterheatertimer.org/How-to-set-timers.html
Link above has instruction resources for analog and digital timer modules.
Repost question and describe timer in detail
Gene
Water Heater Timers Save Money
Jan 04, 2015 | Hardware & Accessories
The "F" LED remains on and I'm unable to get it to change states by depressing the settings button. This has happened on two of the units that are both less than 6 months old. Any ideas?
Copy following link to identify timer, and find comparable product that might last longer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Check output voltage at outlet using multimeter. Should be minimum 80% rated value or 110Volt outlet = 88 volts
Check outlet with circuit analyzer for correct polarity and grounding.
All timers come with 1 year limited warranty, in this case it will be through seller because first alert does not show timers on their website.
Don't buy First Alert products.
They are generally cheaply made promotional grade timers.
I recommend Intermatic HB61RC or Woods 49103 or Intermatic HB65R because their products are good, and warranty policy is direct from company.
Oct 24, 2012 | First Alert Hardware & Accessories
Need instruction manual for pool/spa Intermatic timer model RC 2343PT
Intermatic does not post that product manual, or the door label for that specific product. Nor is the door label clear when viewing images of timer.
Copy following links for possible assistance wiring timer, and then setting timer:
http://waterheatertimer.org/pdf/RC2403RT-Door Label.pdf
Apr 20, 2012 | Intermatic Hardware & Accessories
I have a question regarding the Intex Saltwater pump. If you cannot unlock the keyboard and set the salt timer will the plates on the ionization system still work or are they disabled unit the timer is set...
Must set the timer!!! It will not generate chlorine without setting the timer...
Try these instructions to unlock your timer and set the unit... If this helps, please rate the information.. Thanks and good luck!
Jul 23, 2011 | Intex Automatic Salt Water System for ...
Where can i get a timer for my schumacher battery charger
If the charger is an older version, you may not be able to get any parts for it. In that case, then the only way to continue using the charger would be open it up and bypass the timer right to the solenoid which forces the charger to 'ON' as soon as you plug it in, and then go out and buy a 110volt timer and plug it into that.
Dec 18, 2010 | Garden
Model T104P wiring instructions for 110volt motor
T104 timer is for 240 Volt circuits. It has internal 240V clock motor. Clock terminals and timer terminals are connected, so there is no way this timer can control 110V circuit.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
T101 timer is for 110V circuit.
T101 has 110V clock motor
Both white neutral wires = terminal A.
Black hot wire from breaker box = terminal 1
Black wire to load = terminal 2.
Grounds = green screw
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
T103 timer is for 110V circuit
T103 has 110V clock motor
Black hot wire from breaker box = terminal 3
Black hot wire to load = terminal 4
T1905 timer is for 110V circuit.
T1905 has 110V clock motor
Both white neutrals = Clock terminal
Black hot from breaker = COM
Black to load = NO [load comes on when timer turns on]
Sep 21, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My rm2652 is pluged in to 110volt, the freezer is working good but the lower freg is still warm. what can i check?
ounds as if the evaporator fan motor is not working. Listen for a fann inside ,if you herear it procdeed to 9nvistagat the defrost mode. Rem,ove the freezer back panel to look to see if it is frosted over. If so check the defrost strip, and advance the defrost timer until it clicks. watch to see it defrost if it does replace dedfrost timer.
Jul 15, 2010 | Dometic RM2652 Refrigerator
How to set timer on my hottub
Hi, we have an ampac pulsar series timer on our spa. We are not sure how to set it, as we bought it second hand and have no booklets. Can you help?
Mar 21, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
