Question about Canon ImageClass MF3110 All-In-One Printer
Feed rollers Where is the feeders and do I have to take the copier apart to reach them.
5 Suggested Answers
canontech
  • 1219 Answers
SOURCE: how do i clean roller paper feeder on canonpixma
You need to remove covers or very gently your way
Posted on Jan 12, 2010
SOURCE: Canon PC950 Copier
Hi -- The springs at the 'feeder" door broke. Now the copier wont feed, are there replacement parts? A new door perhaps? I have the same problem.. Need help or place to purchase parts.
Posted on Mar 13, 2010
  • 150 Answers
SOURCE: the feed roller from the fresh paper into the
You can see the feed roller by opening the door on the lower right side. The copier will try to print with this door open. Steven 805-520-3003
Posted on May 13, 2010
rogerfixit
  • 30 Answers
SOURCE: auto feed starts but stops before it feeds the
Be sure to check the white separation pad under the second roller - a known wear item. If that is OK, you probably have a sensor switch problem
Posted on Jun 11, 2010
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
Help-the paper feeder does feed the paper so the amounts print on top of each other.
If the document feeder is not feeding paper properly, the first thing I would suspect is the feed rollers ( 2 or 3 in total,) as they have the tendency to become dirty and worn. My suggestion would be to open the document feeder, take a clean rag and some general cleaner (no solvent,) and wipe down each roller as best you can. This will act to remove any trapped dirt or debris in the feed roller traction marks, and thus give you a more reliable document feeder. However, if this fails to alleviate the issue and the rollers appear worn, replacing them would be your next step.
I would suggest precisionroller.com as a good source for printer, copier, and fax supplies.
-David.
Nov 05, 2010 | Office Equipment & Supplies
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
Canon D480 document feeder doesn't always feed documents
First, try changing some Document Feed Rollers etc.
FC8-9251-000 is the pickup roller
FL3-1023-000 is the separation pad
FM3-8679-000 is the feed roller
That would fix 80% of the problems you may encounter
Whit
Item, Inc.
Sep 28, 2010 | Canon imageCLASS D480 Black and White...
Auto feed starts but stops before it feeds the paper. How do fix this problem. How do I take the Auto Feed apart to find the problem. The rollers start then shut off before the paper start to go into the...
i am not sure how to get to the feed and seperation rollers/pads in this doc feeder. But if you can access them even a small amount you might try using alcohol solution to clean them up and or a green scott bright scartching pad to ruff the surface up a bit to give them grip and to help clean them off some. might even use a little simple green on the pad to help clean them off thena paper town to dry the rest off. this could buy you some time till you can get a new set of rollers to have put into it
Jun 01, 2010 | Canon PC-1060 Black and White Copier
Minolta Di251 Paper Feeder doesn't work. Need estimate to repair
Common problem with these models.....most likely if it sounds like it "tries" to feed you original then the feed rollers need to be cleaned. On the front left corner of the document feeder cover there is a single screw. Remove the screw, open the F1 door and the cover will come off. Now right where the originals feed in you will see 4 feed rollers or small "tires" The 2 smaller ones or the usually the main cause. Just take a cloth with some glass cleaner on it and rotate and cleaned both sets of tires. Reinstall the cover and you should be good to go.
Oct 14, 2009 | Konica Minolta DiALTA Di200 Copier
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Printer will not feed paper. Says it out of paper
are the feeder rollers moving? If so, the paper feeder rollers need to be cleaned.
Aug 06, 2009 | HP Office Equipment & Supplies
Document Feeder Problem
There is no such manual for the HP OJ G85. Disassembly is not complicated. Just take your time.
Inkworks
866-381-0541
Sep 10, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Canon ImageClass MF3110 All-In-One Printer Logo
22 people viewed this question
old marine
old marine
