Question about Card Scanning Solutions Scan2Contacts Pass-Through Scanner
Scanner won't scan business card with Scan2Contacts
I have uninstalled and reinstalled software, cleaned and calibrated scanner. Scanner won't scan a business card.
2 Suggested Answers
  • 332 Answers
SOURCE: My scanshell 800 DXN has started scanning lines
I am very familar with the scanshell scanner you have I have repaired several of them in the past.
There really isnt anything that wrong with your scanner it just needs to be calibrated. When you purchased it there was a calibration sheet included in the box that you need to use I hope you still have it. If not go here to purchase some new sheets http://www.scanshell-store.com/accessories.htm They used to be free but when I looked at there web page they are not listed any longer. Also here is a link to a 800 manual which describes how to run the calibration process http://www.id-reader.com/ftp/applications/manual/scanshell_manual.pdf This will correct your problem and your scanner will be as good as new again.
I hope this helps you out and if it does please leave me some feedback.
Posted on Apr 02, 2011
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
Canoscan won't scan because the other program (?) is busy. I am not aware of any "other program" let alone it being busy.
First thing you'll want to do is reboot and try again. If you do that and you still get the same thing, then you'll need to see what other programs may be running, Ctrl+Alt+Del and then Task Manager (assuming you're in Windows) to see what other programs are running. Close other running programs. Yoiu may also need to identify any hardware or software that you may have recently installed (especially other scanning or TWAIN devices such as scanners, All-in-one devices, digital cameras, web cam, etc.). You may need to uninstall and reinstall the scanner software, though I wouldn't expect that to cause the scanner to be busy.
Feb 25, 2011 | Canon CanoScan 8400F Film Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Jul 08, 2009 | Xerox DocuMate 152 Pass-Through Scanner
SOFTWARE FOR TRAVELSCAN 860
Hi
Here it is:
TravelScan 860
32-bit Windows 98SE/ME/2000/XP: TravelScan 860 V3.2.0.0 [345 KB]
Calibration Note:
To calibrate your scanner use the back of a plain clean white business card.
Feb 10, 2009 | Syscan TravelScan 860 Business Card Reader
Scan does not go into picture programme, just get black picture, but preview shows scans as perfect, this only happens when scanning film
could be a software issue, uninstall and reinstall the scanner software.. the uninstall option should be available on the scanner software folder found in start>all programs..
reinstall the scanner software using the disk that came with it.
Aug 22, 2008 | Canon Office Equipment & Supplies
Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
Sep 03, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Light stripe on scans
Possible causes, CCD failure, smudges or marks that can only be picked up by the CCD if the underside of the scanner glass is dirty. Uninstalling/reinstalling your scanner driver will eliminate if its software related or not. From the looks of it, could be with the CCD if the lines are in the same area with every scan attempted.
Aug 18, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Umax Power Look 2100XL
Hi, Have you tried these possible solutions; 1.Clean the surface of scanner bed. 2.Uninstalled/reinstall scanner driver/software. 3.Check scanner manufacture web site for driver/firmware updates. 4.checked the underside of the scanner glass for lint, dust that may cause a bad calibration.
Aug 15, 2007 | Umax PowerLook 2100XL Flatbed Scanner
Card Scanning Solutions Scan2Contacts Pass-Through Scanner Logo
41 people viewed this question
Top Card Scanning Solutions Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Card Scanning Solutions Office Equipment and Supply Expert? Answer questions, earn points and help others
