Question about Xerox Office Equipment & Supplies
Error massege bypass Expired In 3550 XEROX WC disable Copy Fanction
Error massege bypass Expired In 3550 XEROX WC disable Copy Fonction
3 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: error in xerox 6250dp of fp transfer roller expired
You need a new transfer roller.
Posted on Jan 25, 2009
  • 489 Answers
SOURCE: i have xerox wc 7228, when i try to copy it is
hello
here is the link Xerox offical site about error codes and things that you can do . i hope it useless.
Posted on Feb 10, 2010
Bypass expired
It is recommended if possible that a ConfigurationReport be printed
from the device prior to performing the following procedure to resolve the fault.
Procedure
1. Remove the'Product Enablement Key' (SIM Card) from the rear of
the device.
2. Press[Menu], then[#], then[1934], and press[OK].
3. Select[Machine Diagnostics] and press[OK].
4. Select[Memory Clear] and press[OK].
5. Enter[1934] and press[OK].
6. Wait for the Memory Clear procedure to complete, and the device to
reboot itself.
7. Complete the'Setup Wizard'.
NOTE: If completing the Fax Setup section of the wizard, the device will
reboot again when exiting/completing the Setup Wizard.
NOTE: In the Fax Setup section,'1/3 Fax ID' is the Phone Number, and
'2/3 Fax ID' is the Name ID.
8. Insert the'Product Enablement Key'.
NOTE: If normal operations are still unavailable, then switch the device
off, unplug from power outlet, wait 30 sec, reconnect power and swi
Feb 10, 2015 | Xerox Office Equipment & Supplies
How do I change the cartridge region from a xerox workcentre 3550
The toner cartridges have a small CRUM chip fixed on the end of each tube. If you change them from a previously empty cartridge then it will still show empty. You just can't fool them.
Good Luck.
Jul 14, 2014 | Xerox Corporation WorkCentre 3550 Laser...
My workcentre 3550 multifunction printer is constantly printing the configuration report, how do i fix that?
Anthony,
I'll assume your printer is wasting paper.
Firstly remove the paper, that should stop it, then try and enter Centreware, check the www.Xerox.com website as to how to do that. From there you will have more control from there.
Replace the paper as a check, and hopefully the problem will be sorted.
Good Luck.
May 24, 2014 | Xerox Corporation WorkCentre 3550 Laser...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
I have xerox wc 7228, when i try to copy it is showing ''A fault has occurred press C botton to cancel '' error 009-936
hello
Feb 10, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
122 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
