Question about Astoria Divina AL2 Espresso Machine
Can I run gas astoria machine without turning water pump on, if there's enough water in it?
    President:
  • 1,618 Answers
If it is a lever machine, has a manual fill option and connected to water.
Posted on Apr 05, 2014
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: I have a old style 2 group lever Astoria coffee
Check the expansion valve, and replace the pump you will have to install a check valve in the out port side of the pump.
Posted on Nov 12, 2009
SOURCE: needs astoria argenta sae 2 espresso technical structure/hydraulic parts diagram
pump does not come on when button is pushed
Posted on Jul 03, 2011
Asotoria model aep12n - do I have to use a water softener?
You can use it without one but it would be best to install a water softener system like an everpure ql3 head with a 7S0 softener. That might run you about $200 installed.
Mar 31, 2014 | Astoria Argenta Coffee Makers & Espresso...
Water pump runs constantly
First we have to figure out where the water is going, because if the pump is running the water has to go somewhere. either the boiler or coming out the groupheads or there is a leak? If the groupheads check the manual switches make sure they are in the off position. If the boiler check the wire on the level probe, the inlet solenoid and sight glass to see the amount of water in the boiler. If there are no leaks then there might be a problem with the mainboard.
Jan 18, 2014 | Astoria Coffee Makers & Espresso Machines
Astoria blinking light
If all the lights are blinking the machine is not getting water fast enough.
Jan 12, 2013 | Astoria Argenta SAE-2 Espresso Machine
All the program buttons on my Astoria SAE2 were flickering at once. I turned the machine off and on again and it was gone but am wondering why it was flashing.
if the machine runs on 220, then it will do that with a power surge, because sometimes, when there is a surge, it drops to 110 power it is enough to do this, if it is wire and on 110 power, could be a programing issue that is triggered from a power surge. Most likely it was a power surge, that is common, especially if it is 220 power, machine will run if only 110, power, but wont operated fully for the proper steam, boiler temps etc, if does not have enough amp, just enough to flicker. Hope this info helps. Thanks Mr Bean Man from fixya
Jun 12, 2011 | Astoria Argenta SAE-2 Espresso Machine
We have an astoria model SAE.2 for some reasen the machine has gone very quiet and appears to be strugling when re charging after each use
It sounds like the water pump is not doing its thing or the machine cannot get water, either blocked filter or water line.
Jan 03, 2011 | Astoria Divina SAE-1 Espresso Machine
I am getting steam and or air in water line feeding my machine.
Try adding an accumulator in line after the shurflo pump, that will assist the machine.
Jun 27, 2009 | Astoria Divina SAE-1 Espresso Machine
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Mar 20, 2009 | Astoria Argenta SAE-2 Espresso Machine
Water pump problem
I would just replace the whole pump. you could rebuild it but they never seem to last that long with a rebuild. espressoparts.com should have them for between 70 and 100 dollars. its been a while since i bought one but i remember them being relatively cheap. do you use a water filter? it will extend the pump life quite a bit
Oct 05, 2007 | Astoria Compact CKXE Espresso Machine
Astoria Divina AL2 Espresso Machine Logo
64 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
