Question about RCA 32V420T 32" TV
Rca 32' model 32v434'
Focus control works the same as a screen control. set shuts down 30 seconds later.
  • khosea_81 May 14, 2009
    RCA 32V420T 32"
    Overall TV is Great, One day while watching a movie my tv started turning off and on all by itself for a least 5 minutes until i unplugged it. Next day plugged it back, started working fine again i thought, 10 minutes into it, it started all over again plus stayed on channel static channel 3 searching for channels. Hasn't been right since. Can anyone help me fix this problem? Thanx
    Genius:
  • 1,694 Answers
Probable bad IHVT aka flyback transformer part # 271996
........................................................T.
Posted on Dec 04, 2007
My RCA hdtv d52w23 will turn red screen when you turn it on and a few seconds later it will shut off. Whats wrong with the tv? Ive looked inside it. The red circuit board has a burned mark on it, but I...
If excessive red the set will detect too much current being pulled and shut down----Try to Google the model number with "parts" or if that fails try to contact PTS Electronics who repairs/rebuilds all kinds of circuit boards.
May 14, 2012 | RCA Televison & Video
My tv has a forgotten password on it to block certain channels. How do I reset it or get it off?
I believe Protron is an RCA subsidiary, so an RCA factory reset procedure may work for you. Try the following:
RCA TV:Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds.
Mar 14, 2011 | Protron PLTV-32 Television
NO HAVE THE CODE TO UNLOCK IT. RCA MOD. 14N26
Hello
Your TV has been locked I thinks. There is a way to unlock RCA tv, and you must V-Chip code and other things later.
OK.
Dec 07, 2010 | RCA E13344 13" TV
RCA 32v550t. The parental control has been accidently activated and i can't figure out the code. The front panel has also been locked please help me.
Hello Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works
Nov 20, 2010 | RCA 32V550T 32" TV
My tv says locked on the screen. i dont know what to do with the rmote. it will turn on and the channels will go up and down but says locked on the screen
Hello
As you have its remote things are easy. If you have forgotten the passoword do the following.
make sure the TV is off. Simoultaneously press and HOLD VOL. Enter a next password next time you access parential control menu.
If this does not help do the following
[1] Hold dow n [0] on the remote control and volume [2] Hod down Menu button on the front panel of the TV and 'TV' button on the remote control at the same time for at least 5 seconds.
[3] Hold down "Go Back" on the remote control hanset and "Menu" on the front of the TV at the same time for at least 5 seconds.
[4] Hold down "Eject" on the front of the TV and the "Menu" button on the remote control hanset at the same time at least 5 seconds.
Depending on the model one amoung these steps will unlock RCA tv. OK.
Nov 13, 2010 | RCA 32F531T 32" TV
32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
May 27, 2008 | RCA 32F531T 32" TV
Rca 27v414t shut off by it self after a feww seconds.
Most likely the TV is detecting an internal problem with it's circuitry and is shutting itself off to prevent further damage. You'll need to have a professional look at your set to determine exacly what's going on. Aside from leaving the power cord unplugged for five minutes, then pluggin back in and trying it again, there's nothing anyone can do from here. It may work, but it's a long shot.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | RCA 32V524T TV
Tv controls respond erraticaly
most of these rca models have bad flybacks. also check horz output transistor, if flyback is relaced the screen voltage has to be at or close to 295 volts or set will shut down after on 5 seconds
clintstv
Jan 18, 2008 | RCA 32V420T 32" TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Television shuts down as if thermal problem, but cool
Shorted red driver trans shorted red pic tube defective focus/screen block any or all of these stk's on convergence module check the solder joints on convergence module
Jan 06, 2006 | Panasonic PT-40LC12 40" Rear Projection...
RCA 32V420T 32" TV Logo
229 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
