Question about LG LD65EL Dehumidifier
My dehumidifier model LD301EL is not depositing water at all
No lights on controls but power at theplug willnot start ?
? power at the plug, so power at the socket, but not in unit. check unit fuse in plug, check for fuses on unit, usually at back near to power inlet
Aug 13, 2014 | LG LD301EL Dehumidifier
Lg ld301el
totally dead, check fuses. could be stiffened up over the time and took fuse out on first switch on
Aug 13, 2014 | LG Dehumidifiers
Full light is on and won't turn off
There is a float in the back, make sure it is dropping all the way. If the rear tank isn't fully inserted it will also prevent the full indicator from resetting. Occasionally hard water deposits will build up, and it's usually just a matter of cycling the float up and down by hand a few times till it loosens up.
Apr 24, 2014 | Kenmore 54501 Dehumidifier
Trying to register dehumidifiers bought 2 dehumidifiers at Home Depot Sept 2011 Model LD301EL Serial No. 103TAXTB1930. I want to sign up for warranties. Iam legally blind 79 yrs old & not good with...
Hello Mary. Please have someone help you with this issue. You are at a self help site, for sure, but you need someone who can help you by calling your local Home Depot and/or registering your equipment on the computer.
Please have your helper contact the web master of this site to have your telephone number removed from this listing. This web site is accessed by thousands of people from around the world. Click on the Contact link below to have this post removed.
Thank you
Sep 27, 2011 | Dehumidifiers
The water tank does not fill up with water?
Check your inlet water screen for debris or calcium deposits. Also check float valve operation.
Jul 05, 2011 | Goldstar Dehumidifiers
No water being removed-maytag dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Dec 02, 2008 | Maytag M3DH30B2A Dehumidifier
Dehumidifier -- LG LHD45EL
If everything is clean on the coils and the filter is clean it should work. I would contact LG because they have a 5 year warranty on these dehumidifiers. Make sure that you have your reciept. Usually what they will do is locate a shop near you and it can be serviced there. LG will pay the bill. Or if there is no local shop they will send you a service tag for your old unit and ship you a replacement unit. Contact LG and explain this problem to you. Everything should be covered under warranty still.
Good luck - Tech101
Jun 29, 2008 | LG Goldstar LD65EL Dehumidifier
My dehumidifier looks working fine (normal condensor sound and light) but does not pick up water.
sound like a sealed system issue , if the compressor is running and no moisture is being deposited into the bucket there is an issue with the sealed system that need pro help
Apr 27, 2008 | Maytag M7DH65B2A Dehumidifier
LG LD65EL Dehumidifier Logo
44 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
