Question about Yamaha RX-V2700 Receiver
Connect error internet radio does not work
Honda civic gli radio replacement won't work
Dannielle, if the previous owner installed the radio, it must have worked. It is possible that error code may have no connection with the replaced radio which may work when connected to battery. It depends on the complexity of the new radio. If it is simple, s/b ok.
Jan 03, 2014 | Cars & Trucks
Bose SoundTouch 20 won't connect to internet radio --> 1029 error
Hello, i had the same Problem.
Remove the Soundtouch App from your PC and reset Bose Soundtouch ( press 1 and Volume - ) install Soundtouch App new, follow the instructions and let the default settings.
Do Change not Network Name Bose Soundtouch...
Skip Music Libary from iTunes or Windows Media.
Dec 25, 2013 | BoseĀ® CORPORATION Bose - SoundTouch 20...
Aluratek AIREC01F will not connect to wifi
first need more info is this a secure router connection...does it require a password to login to. if no then i'd refer to this link make sure you meet tehe requirments.
http://aluratek.com/wifi-wireless-internet-radio-tuner-home-theater
if yes i would make sure you entered in the correct password on your new device and if you did try a reboot to clear any possible communication error sit may have gotten.
Aug 20, 2012 | Aluratek AIREC01F WiFi Internet Radio -...
I just installed a linksys 2500 router. It connects to the internet on my iphone4, but I can''t connect to my sanyo 227 internet radio. The radio sends error port 80 not connected. I think I...
Some old receivers including laptops will not connect to some new routers and access points, you can do one thing to solve this problem, access your router with typing this address in explorer 192.168.1.1 (may be different, check your network connection status details to know default gateway)
then decrease your wireless channel from 11 (9 or 6)
then try to connect again, if still not ready replace your router and check again
Thank you, rate me if you understand it...
Aug 29, 2011 | Linksys Wireless-G Broadband Router
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
Problems with Windows Media player connecting to the internet
at first the re-configure ur router and other re-installed the internet explorer ok
Feb 17, 2009 | Computers & Internet
"Failed to lookup DNS" error with Aluratek wifi internet radio
Here's the useless response from Aluratek customer support:
"Failed to lookup DNS, the password is case sensitive, if you are using upper lower case letters you have to key in the correct case otherwise you won't be able to connect your radio. Thanks."
However, Aluratek advised another AIRMM01 owner to obtain a newer modem. I bought a new Actiontec GT724WGR Wireless DSL Modem and that resolved the problem with my AIRMM01F.
Dec 28, 2008 | Aluratek AIRMM01 Internet Radio Alarm...
81003004 problem
go click preferences->click connect directly to the internet (again..even though it has been already chosen)-> choose your connection and connect..i guess it will work..it worked for me..try it!
Nov 02, 2008 | Microsoft Windows XP Home Edition
Yamaha RX-V2700 Receiver Logo
23 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
