Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DGB-600BC water leak - Cuisinart DGB-600BC 10-Cup Coffee Maker
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 6 Answers
SOURCE: DGB-600 grind & brew thermal coffeemaker
dutchman05
  • 487 Answers
SOURCE: Cuisinart Grind and Brew 10
the problem is your drip stop at the bottem of your filter holder.
Check that pls and let me know
Posted on Aug 17, 2008
  • 3 Answers
SOURCE: Where do I purchase replacement charcoal water filters for my coffee maker?
I found replacements at Bed Bath & Beyond
Posted on Oct 17, 2008
SOURCE: DGB-600BC
I have had the Cuisinart DGB-600BC for a bit over a year. The coffee grinds, and then sometime during the brewing cycle, it will go, "beep beep, beep beep, beep beep..." on and on.
I think I have traced the problem to the latch on the top lid that you open to access the bean hopper. I believe the latch sticks and doesn't close the lid tightly enough. It will appear to be closed, but the latch isn't all the way in place.
So, there is a small screw on the inside of the latch in the lid. Carefully unscrew this, remove the screw, latch, and the small spring. Remember which way the latch faces.
With a warm damp paper towel, clean the latch and the slot in the lid that the latch goes into. Reassemble, and make sure the screw is not so tight that the latch doesn't move freely.
This should solve your problem.
Posted on Nov 04, 2008
How can i get manual for Cuisinart dgb800bc
Hi Harrison, The links below are user manual for a dgb900bg and a user manual for a dgb600dg..... Could not find an 800 mate......... CHEERS..
https://www.cuisinart.com/share/pdf/manuals/dgb-900bc.pdf
http://www.cuisinart.com/share/pdf/manuals/dgb-600bc.pdf
Apr 29, 2016 | Cuisinart Coffee Makers & Espresso...
Will the coffee maker work without the charcoal water filter?
Yes, the coffee maker will still work... the charcoal filter is just there to help make the coffee taste better...with most waters it does not matter...high chlorine content water is where it makes the most difference..
heatman101
Aug 05, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Wattage of a Cuininart DGB-600
The consensus seems to be that it is 1025 Watts, although I have a hard time believing it - not even a stand mixer is 1025 watts.
Apr 01, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-600BC - Coffee maker (grinder combo)
Unplug for 20 minutes or longer - this one has a longer than normal reset.
Dec 07, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Water leak
just had the same problem the heater ring at the bottom has a whole in it or the hoses have got a crack in it. use a no 9 torx driver to take the bottom off. the check hold it up get water in it and look for the leak. the heat ring should have white corrosion on it, that should be were the leak is
Jun 24, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Dgb-600bc water draining out of coffee-maker.
Filter machine: I suggest that you check the hose connection between the water reservoir and the heating unit - it may not be connected or may have a hole in it or the clamp may have fallen off.
Jun 21, 2008 | Cuisinart Coffee Makers & Espresso...
Power surge fried our unit
Contact cuisinart and see if the will replace it under warrenty. This happened to mine, but they would not replace mine because it was a refurbished model. I am going to rip mine apart to see if I can fix it this weekend.
Jun 18, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-600BC
Jan 21, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
50 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
