Hp laserjet cp 5225 color problem
I have a hp color laserjet cp 5225,having a color problem,when i print a text color print,printer print same same like different color,so i have to know its a formater board problem or scanner problem
  • 26 Answers
SOURCE: HP Color Laserjet 3500 Problem
Occasionaly these printers fall out of specs so that is why HP made it possible for the user to calibrate the printer:
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer:
1 Press MENU to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight PRINT QUALITY.
5 Press to select PRINT QUALITY.
6 Press to highlight CALIBRATE NOW.
7 Press to select CALIBRATE NOW.
If that doesn't help and want to adjust the colors themsevles,this is how you do it:
To adjust color density
Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE MENU.
3 Press to select CONFIGURE DEVICE MENU.
6 Press or to highlight ADJUST COLOR.
7 Press or to highlight the desired color.
8 Press or to highlight the correct density setting.
9 Press to select the density setting.
10 Press to set the density for the next color.
11 After setting the density for each color, press MENU.
Hope this helps
Posted on Mar 27, 2008
Scott Ellin
  • 558 Answers
SOURCE: Driver of HP Laserjet CP 1215 Printer needed for MAC machine
HP does not currently have software or driver downloads available for your product for that operating system.
So we and you can't do anything to run this printer on your Mac Laptop.
I hope this help you lot.
Please rate the solution.
Scott
Posted on Nov 11, 2008
HP Xpert
  • 112 Answers
SOURCE: HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Posted on Jan 19, 2010
SOURCE: HP laserjet 5550 not printing cycan. Replaced
You will not find the answer to this problem on any forum as I have searched each one! However I have had the same problem and found out that if you have reseantly replaced or reseated the Paper Pic-up assy you may have not pushed down the plastic top cover which sits directly underneath the Cyan Cartridge, this will cause your 5550/5500 to think there is no problem and carry on printing without any error messages.
I'm just a man doing a boys job, lol
Posted on Feb 23, 2010
Testimonial: "Wow! Thank you sir. That was the problem. I had not touched the paper input assembly. So obviously, a user did this. Thanks again!"
  • 223 Answers
SOURCE: HP Color LAserjet CP 2025 printer fails to print.
Make sure the printer is connected directly to the outlet. If there is no display there is no use trying anything else as this is a formatter failure and the printer requires service.
Try a nvram:
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If there is a display,
print out a configuration report
check network settings ipv4addr, check port under driver properties. and make sure the same ip address is selected.
if using usb download a universal print driver and try installing the driver and selecting the usb virtual port
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
Hey! I have just installed my HP Colour LaserJet CP 1215 Printer to my Laptop which is istalled Window 7. However, the printing speed is too slow . How can i fix it? I 'll appreciate your help.
We have found this is in some cases and the solution that seems to work best is to download the HP Universal Print driver and install it instead of the driver that comes with the printer.
May 19, 2011 | HP LaserJet CP1215 Color Printer
HP Color laserjet p3505 printing entire pages pink
Cartridge Magenta Failed, replace it for a new one.
Jan 24, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
HP COLOR LASERJET CP 3505 N PRINTER: Magenta toner is light in color.tryed changing the...
Known problem with this machine the fan is located next to the magenta laser scanner at the base of the machine. this fan blows dust on to the scanner lenses and makes the prints light. Needs to be taken apart and cleaned. take it to a local service center if they know what they are doing should be less then an hour.
May 18, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
jasbo
jasbo
