Royal CIA 12X Paper Shredder
Hi
I had a problem with this shredder, it froze up I took the entire cutting Mechinism out and found a frozen gear on a shaft, I was able to remove it polish the shaft now it spins fine but I can not figure out how to get the 2 rotary
cutter shafts close enough together so I can put the whole assembly back together.
HELP1 PLEASE
fellowesrep
  • 102 Answers
SOURCE: Royal CIA 12X Shredder Problem
If your machine has an electronic paper feed sensor try cleaning the sensor with a qtip dipped in rubbing alchohol.
Posted on Mar 02, 2008
fellowesrep
  • 102 Answers
SOURCE: paper shredder gear is stripped.....replacements?
Best bet is Royal Customer Service at 888-261-4555
SOURCE: royal 160MX paper shredder
Great site for all Royal Shredders gears & parts.
http://www.geocities.com/jayrespler2/index.html
Posted on Nov 10, 2008
FixinFax
  • 3085 Answers
SOURCE: Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Posted on Aug 02, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Paper is heavly weged in between cutters on both
after you unplug the machine;
use a crochete needle's hook or, a rat tail comb to very carefully pul the paper out
Posted on Sep 14, 2009
Need part # cia12x-70d royal paper shredder
Give Royal a call at 1-800-524-0799. for parts assistance.
Jan 16, 2011 | Royal CIA 12X Shredder
Our shredder motor is working but it will not go forward to shred. It will reverse. I've unjammed every visible paper jam but still nothing. HELP!
If it wont run forward but does run in reverse you may have lost the PCB inside.... contact Royal at 1-800-524-0799 for parts assistance and pricing.
Nov 29, 2010 | Royal CIA 12X Shredder
My Royal 12X paper shredder runs only in reverse but will not run forward. I have noticed other postings regarding cleaning the sensors with rubbing alcohol ant that has been done but was not succesful. ...
If cleaning the eyes did not help then you will likely have to change parts ...you can contact Royal at 1-800-524-0799 for parts and pricing information.
Oct 29, 2010 | Royal CIA 12X Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Shredder only operates in reverse
Check and try cleaning the "eyes" in the paper throat... if that dosn't fix it it could be the pcb inside...call Royal at 1-800-524-0799 for parts help.
Feb 17, 2010 | Royal CIA 12X Shredder
The green light stays on but it will not shred any paper. The reverse works fine. For the Royal CIA 12 X Shredder
Try cleaning the "eyes" in the middle where you put the paper in...if that dosn't fix it then its probably the pcb inside thats defective...give Royal a call at 1-800-524-0799 for parts and prices.
Nov 27, 2009 | Royal CIA 12X Shredder
Model 12x royal paper shreddewill run in reversre but not forward
move the control button on top of the shredder to the oppoiste direction.
Nov 28, 2008 | Royal CIA 12X Shredder
Mar 01, 2008 | Royal CIA 12X Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
k24674
jasbo
jasbo
