Error code 32061;plc drive communication
Booting problem due to the above stated error code; communication and information exchange between the plc and the drive.
  • 398 Answers
What's the spec? Could be a dodgy hard drive.
Posted on May 11, 2014
5 Suggested Answers
SOURCE: hal.dll file missing, can't boot
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Posted on Apr 26, 2009
  • 8 Answers
SOURCE: dvd boot error problem....
That error probably came from the CD ,doing a search on "bootscriptor" returns several links regarding bootable CDs.
Posted on Jul 15, 2009
  • 192 Answers
SOURCE: Dvd boot error problem....
Hi there
Have you tried updating/flashing your BIOS. Only a suggestion, and does not always solve the issue, as some mobo's and bios' don't like the 64bit OS. Don't forget that flashing the BIOS is also VERY risky.
Regards
Tim
Posted on Aug 28, 2009
gmuhirwa83228
  • 66 Answers
SOURCE: acopos 1090 booting problem
The issue is that the line filter and the integrated resistor can not secure the restart, so you have to check with your "resistor"
Posted on Feb 15, 2014
What is error code C0 on aeg dishwaser.
C0 is Communication Error
When no data can be received between input module and main PCB after 10 attempts
Check th Communiation cable and port on PLC
AEG Favorit 80800 Service Manual Fault Codes
Oct 26, 2017 | AEG Washing Machines
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Ce code
CE
Communication error
If communication between the ignition board and the display board is not established within 3 s of power-up an error will be displayed. After communication is established, if it is lost for 30 s, the error will be displayed. The error code will be cleared upon a valid data exchange between boards
All you can do is remove the panel and make sure that the connection between the two boards is good and dry. Other than that, you will be changing cable from the lower board or the lower board itself.
Jul 02, 2014 | Hayward H Series
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Acopos 1090
Sir What section bower board and control cart what section check the" resistor" sir
Feb 14, 2014 | Kitchen Ranges
Acopos 1090 booting problem
Feb 14, 2014 | Computers & Internet
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
The CE code is showing on screen
Communication error
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
F 11 error code on Whirlpool Duet - Serial Communication Error ?
Your F11 Code is stateing these things but if it is intermittent probabbly a loose connection.
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Jan 20, 2009 | Whirlpool GHW9300 Duet Washer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Computers & Internet Logo
David Payne
David Payne
