Question about TT Systems Lands Phones
Tt phone won't dial out - TT Systems Lands Phones
Www office com setup
You can activate by calling:
  1. Call the Activation Center.
The Customer Service representative will ask you for your installation ID that is displayed in the Activation Wizard and other relevant information. After your installation ID is verified, you will receive a confirmation ID from the Customer Service representative.
Microsoft Text Telephone (TT/TTY) services are available for people who are deaf or hard of hearing. In the United States, use a TT/TTY modem and dial (800) 718-1599. From outside the United States, use a TT/TTY modem and dial (716) 871-6859. TT/TTY service is only available in English.
Nov 21, 2013 | Computers & Internet
Have a 1976 Mickey Mouse push button phone. I get a dial tone, but not able to dial out
This may be something as simple as REVERSING the line wires or a bad tone pad. Some pre 1980's tone pads didn't have polarity guard (EPG) and that's what we used to restrict dialing on touch tone lines (poor man's dialing restriction).
You can open up the jack the phone plugs into and reverse the red and green wires, or open up the phone and do the same thing. If it were my choice, I'd reverse the jack. If that doesn't fix it, pry off the faceplate cover over the dial, read the part number on the right side of the tone pad and post back. I'm sure I have an equivalent in the warehouse (outside of my 2 TT Mickey's) that I can give you a price on.
Carl
Jun 20, 2011 | Disney Classic Mickey Mouse Telephone
How do I change the number of rings on my lg phone before it goes to voice mail
This is usually set by your network provider, so you have 2 choices.
1) Call the network Customer Service number and ask them to extend the time before it diverts.
2) Try the following network code to change it yourself:
**61*XXXXX**TT# (then send/dial)
XXXXX = The number you dial to access your voicemail (if it starts with a zero remove it)
TT = The time in seconds before diverting. The maximum value is usually 30, although some people report problems when using 30 seconds. I believe the maximum is specified by the individual network, so try different value 15 / 20 / 25 / 30.
Jun 19, 2010 | LG RUMOR Cellular Phone
Date and time on an audi tt 2000
the little dial on the side of the date and time screen, you pull it out once and the hours will start flashing and then you turn it to get the desired hour and then pull it out again to get to the minutes and so on...
Nov 08, 2009 | 2001 Audi TT
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
I need to find out how to return to a normal tone
There should be a button on the phone labeled 'tt/pulse'. The button should be moved to the 'tt-touch tone' position.
Apr 16, 2009 | Lands Phones
Snapped timing belt on 1.8t audi tt engine. Belt snapped not possible to mark bottom pully. help
just fixed my Audi TT ... timing belt snapped so the head had to come off to replace valves. used dial guage on top of piston !
if head is on then there is a plug you can remove that allows you to see top dead center..
Jul 14, 2008 | 2002 Audi TT
Lands Phones Logo
16 people viewed this question
Top TT Systems Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a TT Systems Lands Phone Expert? Answer questions, earn points and help others
