Question about HP Color LaserJet Enterprise CP5525xh Laser Printer
PRINTER CAN NOT PRINT AFTER INSTALLATION - HP Color LaserJet Enterprise CP5525xh Laser Printer
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
My printer will not print. It prints a test page fine, but will not print any other documents
hi,
  • Check the status of your printer by moving to printers and faxes on the start menu.
  • Is it checked?Are there any queued print jobs?
  • Turn off both the printer and your PC.Remove the usb connections.
  • Unplug them completely from power.
  • After a few minutes connect them again.
  • Try to print.Cant print?
  • Uninstall printer[hoping you have installation disk] and install it again.
  • Make sure the selected ports on pc and printer correspond.
  • After installation restart your pc.
  • Now you can print!
Sep 20, 2011 | HP Photosmart C3150 Printer
Installing HP4795 printers in Windows XP. During install XP cannot find print drivers. Can you tell me how to point install to the print drivers?
Click on the link below to download the Printer Drivers and later install them.
Download Link
After you download the file, run the file to start installation and complete the installation.
Disconnect the Printer cable before the installation starts and connect it when asked to.
If for any reasons, it does not recognize the printer connected, complete the installation by clicking on the option ( I will connect the printer later ) and complete the installation.
Then Click on the Diagnostic download option below to run the diagnostic tool to diagnose the issue.
HP Print Diagnostic Tool
My Suggestion would be to completely uninstall the software and reinstall it using the Download Drivers option above in this solution.
Thank you for contacting FixYa
Regards,
Ron
Dec 23, 2010 | HP C4795 AllInOne InkJet Printer
The Printing Services of my printer hp deskjet D2460 is in arabic
what do you call for the installer so that i can print to my printer an arabic font? because every time i print, the printer cannot print the arabic font?
Aug 03, 2010 | HP Deskjet D2430 Printer
I have a HP PSC 1350 and it is giving me a paper jam message, but there is no paper jam. It won't let me print anything now. What can I do to fix this. I've tried turning it on and off but that doesn't...
First off all, turn OFF printer, disconnect it from computer, restart computer, connect printer and turn it ON, please try to print now, even if it does not print,. you need to reinstall printer driver, for that-
1. Disconnect printer, insert printer installation disk in drive, uninstall the printer first and then install the printer.
2. If you don not have the printer installation disk then please visit- http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=306888&lc=en&cc=us&dlc=en&lang=en&cc=us, select the operating system and download the full printer driver and save it on desktop.
3. Disconnect the printer and install it from the downloaded driver, follow the instruction mentioned in installation process and try to print once the installaton is complete.
Hope, this would fix the issue.
Mar 29, 2010 | HP PSC 1350v All-In-One InkJet Printer
It won't print after installation of new ink jet
Here's a link to the Epson printer troubleshooting guide...if this helps; please indicate so.
http://er.epson.com:8001/start
Nov 10, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Trying to install HP J4680 AIO printer and installation fails at
jim it is ur printer driver problem because ur software is damage u need to download the driver from net. or purchase a new driver.
Mar 24, 2009 | HP J4680 Office Jet All-In-One Printer
How do i get my printer to print from my pc
depends upon the type of printer u hav,,, if u hav a printer with a USB interconnecting port then u can plug it into ur laptop rightaway by inserting the USB Cable into the laptop's jack. if ur OS is latest then it will automatically detect the printer and its specifications and installation from the CD is not required. else u'll need to install the software for ur printer from the CD provided by the printer company. then give command to print as normal after installation.
Nov 12, 2008 | HP Officejet 5610 All-In-One InkJet...
Won"t print- will copy:
You need to reinstall your printer driver. If you have the installation cd,
1. unplug your printer from the computer,
2. install the driver from the cd,
3. plug your printer back into the computer
4. turn the printer on
5. print your document.
If you do not have the installation cd, try the printer manufacturer's web site for the print driver. Before installing the driver, disconnect the printer from the pc to make sure installation goes smoothly.
Once the driver is installed, when you plug the printer into the computer and power it on, the computer will find it and finish the installation process automatically.
This will not help the problem posted by guest. His problem is totally unrelated.
Dec 06, 2007 | HP DeskJet F380 All-In-One Printer
HP Color LaserJet Enterprise CP5525xh Laser Printer Logo
15 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
