Question about Tivo Televison & Video
Tivo Premier xl4 won't work right with Charter Cable tuning adapter
Local channels, home shopping and religious channels are all I get, even with tuner adapter. Been trying over a year. Any suggestions.
    Problem Solver:
  • 8 Answers
You need to have a cable card from Charter inserted into the TiVo, and it'll have to be "paired" with the equipment at the cable company's head end, and on top of that, if they do what's called Switched Digital Video, where some channels have to be specifically asked for every so often to get put on the cable at "some carrier frequency", you need what's called a tuning adapter which is a separate box that connects to the TiVo via a USB cable, and which also connects to the cable company cable (best way is with cable splitter so that one leg "dead ends" at tuning adapter).
First you need to take the tuning adapter out of the system entirely and make sure the cable card is working. Then you can add it back into the mix.
And you may need to harass Charter's customer service department a lot to get this stuff to actually work.
A good place to ask further questions about this is the TiVo Community Forum (which is not an official TiVo, Inc. site), which is where lots and lots of knowledgeable TiVo users hang out and help each other.
http://www.tivocommunity.com/tivo-vb/index.php?
Posted on Jul 27, 2014
5 Suggested Answers
  • 4 Answers
SOURCE: tivo not working correctly
Cable chanels an dtv chanels are not the same
Posted on Oct 30, 2007
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
SOURCE: How To Hook Up Tivo Series 1 With A Digital Cable Box?
http://support.tivo.com/app/answers/detail/a_id/1350
Posted on Aug 21, 2009
How do I set up a tivo series2 to a new digital tv. Do I need analog to digital converter?
Analog to digital converter is for OTA transmission. You are using a cable system, right? If so you have to feed into your Tivo the cable output signal from your cable box and set your tivo to correct rf or video input. Since cable tuner is determining channel all you can do to record is set the channel on your cable unit and program your tivo to turn on and record the input at appropriate time..
Aug 28, 2017 | Tivo Televison & Video
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Tivo XL4 constantly reboots
If you have done the usual thing - i.e. pulled the plug and done a forced restart and the problem continues, you've probably got a bad hard drive and will need to replace the unit. But I trust you have called Tivo tech support at 877-367-8486. If you are an existing Tivo Customer, which it sounds like you are, they've got good deals right now - if you call them - for new ones - prices ranging from $129 for a straight XL and $199 for a 4XL
Dec 31, 2013 | Tivo Premiere Elite XL4 - HD DVR
No video from an Apex digital converter box to TIVO
You may have to set the channel 3/4 switch on the lower right rear of your TiVo to match the output setting of your Apex converter. If your Apex converter is equipped for L/R audio and video output you will get better results using a three-conductor cable to connect to your TiVo.
Dec 08, 2013 | Toshiba DVD Recorder AND Series2 TiVo...
Comcast cable channel one off from Tivo channel
I've never, ever heard of this problem - having been a happy TiVo user for over 15 years. The very first thing I would do is call Comcast and tell them what is occurring. How long had everything worked OK before this happened? If things were OK for a long time before this, and if your TV carrier was, likewise, Comcast for a long time; and if you haven't gotten a new TV or cable box for a long time, then the problem must rest with Comcast. It must!
In our home, with the number of movies, shows/sporting events/etc. which we record, that would be totally unacceptable!
Try this: Unplug everything (with everything turned off). Make sure your TiVo remote is good (fully charged batteries and the code is right for your TV/cable box), Wait for 10 minutes and plug everything back in, starting with TiVo, then the TV, then any other accessories.
Plug back in and do a complete restart from scratch - like you did when you first set up TiVo.
Make SURE that your receiving channel (3 or 4) is the same on both. It could be that someone accidentally has changed it - are there kids in the house?
If none of this works, get Comcast in there. That's all I can tell you. . .
JB
Apr 11, 2017 | Tivo Televison & Video
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Non-HDMI Tivo connection
The solution I use is S-Video from cable box to TIVO, and from TIVO to TV. That gets you the highest quality signal that the TIVO can handle. To watch true HD signal, switch TV from S-Video input to Hi-Def input and tune to HD channel. I have an HD cable box connected to both outputs, your situation may be different.
Feel free to ask for more help.
Jeepster77
Jan 16, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tivo not working
Looks like you only have one tuner hooked up (one cable ) to your tivo. You need 2 in order to work properly
Oct 28, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Televison & Video Logo
89 people viewed this question
Top Tivo Televison & Video Experts
Computer Repairing
Computer Repairing
Dave
Dave
Level 1 Expert
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
