Question about Shark Steam Vacuum, 2-in-1 Vac-then-Steam
Steam won't come out the bottom - Shark Steam Vacuum, 2-in-1 Vac-then-Steam
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
My steam mop steam coming out of the top not bottom any solutions?
Check that the cap or lid has been screwed on tight and that it is seated properly. Make sure the seal or o-ring is not missing.
Aug 12, 2014 | Vacuums
Where can I get a diagram of the inside of a Shark Steam Mop, Model S3901
Unless you\'ve been using distilled water in this unit, it will be collecting a sort of scale layer of calcium, lime, etc, on the interior walls of the steam chamber. When you clean the unit, with a cleaner of your choice, you will get a lot of this stuff off and out when you drain, but frequently there will be a few small chips that will decide to break loose after the main loosening and draining. Sometimes one or more of these errant chips of scale will find it\'s way to the heat channel of the unit and won\'t let the heat out, even though you just cleaned it. If you have or can find, one of the large paper clips, bend one of the tangs out straight and use it to sort of bore out the holes in the bottom, this will sometimes help tremendously. Occasionally, a second dousing of the same treatment is in order, to pick up those last little left over pieces.
Apr 28, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
I have a euro model s3325 and when i turn on the power switch it says its steam ready but will not heat up
I think it may be from the same issue stated above--the thermal fuse blew. I have the exact same problem. This is what someone posted earlier:
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Now to figure out how to get to it!!!
Aug 12, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
No more steam coming out.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Apr 19, 2009 | Bissell 1867 steamMOP Stick Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Shark Steam Vacuum, 2-in-1 Vac-then-Steam Logo
56 people viewed this question
Top Shark Vacuums Experts
JoeVacs
Thomas Perkins
Thomas Perkins
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
