Question about Pyramid 903G 10-Band Car Equalizer
Want to change four output speakers to two
L + R Front and L + R Back speakers to change connection to have only a L + R output
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Connecting four speakers(, left right front, and left right rear)t and a 50 watt subwoofer to a pioneer avh-p4000dvd without using an amp.
This has four outputs with about 22 watts RMS and four pre- amp outputs. So if you need to get the 5.1 effect an amplifier is needed to be connected so as to get the center ampflier and the subwoofer activated from the preamp outputs.
The amplifer on the DVD can be used for surround effect - rear speakers - as the front can be powered by the amplifier.
please check this interesting review
Oct 01, 2011 | Pioneer AVH-P4000DVD Car DVD Player
How do i connect my reciver to my lcd hdtv so the audio is coming from my speakers not the tv speakers.
kindly get four audio RF connection wires look for the audio output on the front or back of your tv. one of the output connection is white the other is red.look for the same connectors on your reciever the same colour.but they are marked input.plug the output wires from your tv to the input connection of your reciever.if you have separate speakers, connect the speaker wires from the output connectors of your reciever so you can get sound comming from your tv through your reciever,good luck.
Sep 25, 2011 | LG Televison & Video
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
How do i properly connect the wires for a JVC SX-SW5th
Connect the speaker output of the reciever to the input of the speaker. Make sure you connect negative receiver output to negative speaker input and positive receiver output to positive speaker input.
Sep 15, 2009 | Audio Players & Recorders
Sony cdex-m630 connections with an amp
You can use either set of RCA outputs for the amplifier that you want to. Only difference in either of them is front, rear and sub outputs. If you are only powering a sub amp, then use the sub outputs, otherwise, the other two will work fine. You can still use the outputs from the radio itself to power four other speakers while using the RCA outputs.
Jun 26, 2008 | Sony CDX-M630 CD Player
I have a creative 4.1 Speaker system but only Front speaker seems working???????????????
I have 4.1 creative speaker but only front 2 speaker will work
so i have connected convertor ie,2 output and 1 input then i connected to the green port so all the speaker are working.
Gowrish
Jun 15, 2008 | Creative Labs FourPointSurround FPS1800...
Speakers
You have A and B output on your amp.For example you can connect two speakers on A and four on B but first check impedance of the speaker.Use four pioneers but make serial connection (+ wire of one speaker goes to +Rout,-of that speaker goes to + of another one and then its - to -Rout of the amp.Same thing for left channel.Thats for B output.For A simply connect speakers.By choosing A or B ON or OFF you'll get two or four speakers working.If A and B is ON all six will work.I hope that this will help you
Feb 29, 2008 | Audio Players & Recorders
Pyramid 903G 10-Band Car Equalizer Logo
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
