Question about Texas Instruments TI 30XIIS Scientific Calculator
I don't know if maybe my calculator has a function turned on that rounds the answer to a whole number? But here is an example: 106 x 6.32 = 670 according to my calculator, which is wrong. The real answer is 669.92. My division does the same thing as well: 106/6.32 = 17 according to my calculator. Real answer is 16.7721519. Is there a key I need to press in order to fix this or is my calculator just busted?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Your calculator is set to display no digits after the decimal point. To change this, you have two options: press 2nd [SCI/ENG] then select "FLO" for floating decimal or press 2nd [FIX] then select the desired number of digits after the decimal point (or F for floating).
Posted on Feb 14, 2014
3 Suggested Answers
  • 8064 Answers
SOURCE: Trying to determine if the TI-30XA Calculator is
You will readily agree with me that there is surer source of information than the guide book. Here is a link to it.
Posted on Sep 10, 2011
  • 3 Answers
SOURCE: The division row of buttons on my TI-84 don't work. Is there any way to fix it by myself or get it fixed real quick?
check button row for small dirt or corner of one button jam into case. use air blower on calc
Posted on Oct 18, 2011
How to calculate mode with caso fx-991ES
MOD simply calculates the remainder that is left over after dividing by the MOD parameter.
For example, 10MOD7 = 3 since you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg 389487MOD31 you start by dividing 389487 by 31, which gives 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD calculation has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculators working capacity.
An alternative method is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Feb 23, 2013 | Casio FX991ES Scientific Calculator
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
Large factorials ti84
The TI-84 is limited to numbers with at most twelve significant digits.
If you must know the EXACT value of 16!, try this. Calculate 14!. Note the two zeroes at the end. Strip them off by dividing by 100 and remember the two zeroes. Multiply by 15. Strip off the last zero by dividing by 10 and remember that we've now stripped off three zeroes. Multiply by 16. Add the three zeroes at the end to get a fourteen-digit number.
In this particular case the result is exactly what you get by using the FACT function. That's also true for 17!, but it breaks down past that because 18! has more than twelve significant digits.
The whole point of the calculator is to allow you to do calculations with a reasonable degree of accuracy, as opposed to exactly. You'll notice that it can't do a simple operation like dividing 1 by 3 and produce an EXACT answer---only a twelve-digit approximation.
Oct 03, 2012 | Texas Instruments TI84Plus Graphic...
Round function in a program
There is a round( function called round( . Example round(1/3,4) rounds fraction 1/3 to 4 decimal digits. You find the function in the CATALOG, or under MATH>NUM> 2:round(
Jan 16, 2012 | Texas Instruments TI-84 Plus Calculator
I have a problem with my Sharp EL-531WH Scientific Calculator. It rounds off the answer. In my Chemistry class, we need exact answers. For example, an answer of 0.234 must be the answer if that's the...
Press the [SET UP] key, followed by the 0 key to bring up the display menu. You can select "FIX" followed by the number of digits to the right of the decimal point, or press cursor-down and select one of the NORM modes. Press [ON/C] to exit the menu.
Be aware that some numbers cannot be displayed exactly. For example, 1/3 is a 0.3 followed by an infinite number of 3s.
Jun 25, 2011 | Office Equipment & Supplies
How to calculate a percentage - whole numbers
Say you want to know what percent x is of y (or To find out x is what percent of y).
We take x / y and times 100. Depending on what x and y are this might not always be a whole number,
we could round the number off to a whole number. An example: 81 is what percent of 135? To solve this
take (81 / 135) * 100 = (0.6) * 100 = 60 percent.
Mar 29, 2011 | Office Equipment & Supplies
Excel 07 truncuating problem
You need to use the ROUND function.
E.g. type: =ROUND(A1,2)*A2
Assuming the 2.131576 is in cell A1 and 1000 is in A2.
The round function round the value to 2 decimals (in this case because I specified 2 as the second argument).
May 06, 2009 | Keystone Excel 2007 Essentials for PC...
Rounding function on my TI-30xIIs calculator, it won't turn off.
This function is FIX or FSE near the dot [.] or above it, so press [2nd] the the [FIX] where it located button [.] for example then the dot [.] him self: [2nd] [FIX] [.]
Rate me, thanks.
Apr 16, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Texas Instruments TI 30XIIS Scientific Calculator Logo
121 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
