Question about Whirlpool Dryers
How to change dryer from 3 prong to a 4 prong
  • 262 Answers
SOURCE: 4 prong dryer cord to 3 prong dryer cord
YES NEUTRAL GOES IN THE MIDDLE L1 AND L2 WHICH ARE HOT GO TO THE LEFT AND TO THE RIGHT LIKE THE CORD IS LAID OUT
Posted on Dec 11, 2007
jsrock516
  • 5911 Answers
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
  • 2920 Answers
SOURCE: Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Posted on Jan 29, 2009
jsrock516
  • 5911 Answers
SOURCE: front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
No..you need to replace your 3-prong power cord with a new 4-prong power cord. The following link explains how:
It is a requirement that newer homes have the 4-wire outlet configuration. If your home came with this style outlet, you must update the appliance to be within the National Electrical Code specifications.
The main difference is the way the Neutral (WHITE) wire and the Ground (GREEN) wire is installed. The neutral and ground are independent of each other in a 4-wire configuration. Simply put: Ground the green wire to the equipment cabinet or ground lug. Remove any grounding strap that is on the terminal block for the neutral wire. The instructions I provided will explain this.
If you have any questions, please ask. I hope this helps you.
Posted on Jul 16, 2009
Controlfrk
  • 304 Answers
SOURCE: need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Posted on Oct 04, 2009
Maytag Neptune dryer went from 4 prong to 3 prong...cabinet light works but dryer we won't star
It's not wired right. You're only getting 110 vac to the machine which is why you are seeing some lights but no operation. Make sure when you went to the three prong plug you connected to both 110 vac lugs and common.
Feb 17, 2014 | Dryers
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Change Maytag dryer 4 prong plug to a 3 prong plug
The cover on the back should only be held on by screws and are usually easy to get off. Have you checked for these?
May 04, 2012 | Dryers
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
I am going from a 4 prong to a 3 prong i do not have the manaul for the dryer and the 3 prong plug is not color coded there are 4 conectors and neutral on the dryer the 3 prong wire has 2 conectors and a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 02, 2010 | Roper REX4634KQ Electric Dryer
Need to change 4 prong drier plug to fit 3 prong eletric
Purchase a 3 prong dryer cord. It is simpler and safer than changing the wall outlet.
Nov 03, 2009 | Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Dryers Logo
12 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
