Question about Konica Minolta bizhub C250 All-In-One Laser Printer
When a print job is sent to my Konica Minolta Bizhub c352, it only flashes "data" light, but nothing prints.
  • Konica Minolta Master
  • 6,161 Answers
Does this happen when you copy. Try different document and program pdf word web page etc. Static IP or DHPC? Recommend static IP for copier/printers
Posted on Dec 30, 2015
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
SOURCE: SMB Scanning to a Macintosh
SMB can be a bit tricky on Mac as the aliases etc, & paths can easily overwhelm the MFP. Try FTP as a better alternative. Use "Locations" on Mac to setup a static ip# they can switch to when scanning. I have found the KM machines a bit more fussy than Canon with regards to SMB as you can usually browse better on the Canon devices. I have seen the "Reference" browsing on KM allow you to see into the Mac yet will not allow scanning to the set location. Our KM reps always recommend using the ip# of the device vs Netbios name. To me that sort of defeats the point of using SMB anyway. Scan to PC over SMB seems ok to computer Netbios name as long as DNS is registered & working OK on the LAN & WINS is properly configured as well.
Posted on Jan 21, 2009
SOURCE: Problem with my Konica Minolta bizhub 350
it gives the error code c3451 when i send a work to print
Posted on Aug 12, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
"Konica Minolta C352 - cyan and white pattern background on every print?!
What are you printing a Word document when this happens ?
suspect pattern may be in the software you are printing from.
Go to software help screen and look search for removing background pattern or removing watermark.
Apr 11, 2014 | Konica Minolta Bizhub C352 Digital Copier
Hi Kenneth,
This can be a number of reasons.
When you go into the job list and look at the job history, Is there an error message saying "Deleted due to error" or something similar to this in there?
If it does, highlight the job and select "Details" to the lower right and please post what the "Error details" are.
Feb 14, 2014 | Konica Minolta bizhub C250 All-In-One...
I have the bizhub C352 - I want to print the utility/counter (meter readings). How do i do that. Previous machines had me go to Utility - admin management - copy track - Copy track data - & hit the...
to print meter readings perform these steps. 1-press "utility/counter" 2-press "details" 3-now at the left side of the screen you will see a "print" button, press it and get your copy.
Oct 20, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a BizHub C253 and the data light just flashes. NOTHING prints ??
your machine have a low level firmware... you need to flash your machine.. with a updated version...
Jul 10, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
WHY IS THERE A BLINKING ORANGE LIGHT ON BIZHUB C353 AND NOT PRINTING?
That is not much to go on, but it is possible that the print job got sent to the wrong tray. Say you printed a job to tray 2 which has legal paper in it, but the job is formated for letter it could lock down printing until the job is canceled and sent to the right tray. If there is an error code try and shut machine off and on using the main power switch inside front door.
Jun 04, 2009 | Konica Minolta Office Equipment & Supplies
Data light flashes , documents won't print.
this is not a network problem.because machine is receiving documents thats why light is blinking. check the paper in the tray whether they are of correct size, change the paper size from computer, or call your tech service rep it may be due to usb cable or faulty network cable, or it may be the problem of main communication board of photocopier machine.
Feb 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
166 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
