Question about Frigidaire ATF6000ES Front Load Washer
Drum off track - Frigidaire ATF6000ES Front Load Washer
Why is my washer making noise like the drum is out of line or something is stuck in the track
Is the pump running all the time
trying to remove the water?
Under the machine maybe a diagnostic
manual
You can remove the front cover on some
machines,probably have to tip it over to work on it
You need that service manual
Jul 15, 2014 | Kenmore HE2 Plus Front Load Washer
My dryer sounds like my washer agitating off track
Your drum has disconnected from the rail in the dryer. Sometime a bolt can work its way out and the drun can get off track. Remove back of dryer and see if you can get the drum on its track and see if you can find the reason why it came off.
Oct 15, 2013 | Kenmore HE2 Plus Front Load Washer
Samsung WF218ANW drum tilted off track
It may be a suspension spring has come off or leg has broken if it is both drums off track.
If it's just the inner drum then the bearings may have failed or the spider that the shaft is connected to may have broken.
Start with the springs at the top and suspension first.
Dec 29, 2012 | Samsung WF218ANW 4.0 cu. ft. High...
Adjust tracking go on go video vr3930
Tracking will only adjust on the VCR and may only be on the original remote.
Note that if there is tape debris or black residue on posts and guides or even video head drum tracking will not adjust--any debris will cause tape to move away from the drum resulting in a tracking like issue---tape cleaners rarely resolve this.
Jun 13, 2012 | GoVideo VR3845 DVD Recorder/VCR
I have nuendo 3 hooked up via midi out by a m-audio 1X1 usb midi cable to a yamaha qy70. The QY70 is receiving the signal, but, everything is coming in on midi channel one. Whenever I set the drums on...
the changes which you make should be selected and set to a default mode.other wise the changes will get deselected to what it was default before automatically. in some cases its the software issue,.so reload the software again as new and check out. also check the connections its a rare chance but many times its possible,
check out.keep updated.thanks.
Jan 25, 2010 | Steinberg Nuendo 3 for PC
Having trouble getting new blade to install.
You have to release the blade tensioning device to allow the blade to slip over the drums, then re-establish the blade tension. It should be firm enough to prevent the blade from slipping on the drums. If the blade wants to track toward one side, either the upper drum bearing is bad, the track adjustment is incorrect, or the drum drive surfaces are badly worn. Good luck!
Oct 15, 2009 | Saws
Drum set
I USE THE INTERNAL DRUM MACHINE ALL THE TIME, BUT ONLY ONE TRACK AT A TIME PER SONG. I CAN CUSTOMIZE THE SONG BY CHANGING THE TEMPO, STYLE, AND LENGTH. EACH SONG SOUND GREAT. TRY IT. (DAYSHIFT).
Jan 31, 2009 | Tascam 2488 Portastudio Multitrack...
Drums for MIDI track to not work
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
Jan 18, 2009 | Sony Acid Music Studio 7 Full Version for...
Drums on sx3
Hi!
You can put the drums manually with the drum editor. To do that, place the left and right selectors (the blue zone you can loop), I mean select an area first. Then, double-click in the area, on the track you want to make the drums. A midi segment will appear on the time-line. Double-click this segment, and it will take you in a drum editor. It's easy to edit, you will get to know it fast.
May 26, 2008 | Steinberg Cubase SX3
Drum track
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
http://www.tascam.com/details;8,16,5,19.html
Feb 13, 2008 | Tascam 2488 Portastudio Multitrack...
Frigidaire ATF6000ES Front Load Washer Logo
10 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
