Question about NetGear Computers & Internet
RCA Tablet's WiFi Unable To Connect Thruough Netgear Modem
    New Friend:
    Problem Solver:
  • 15 Answers
Need to change the mode of wifi to 54 mbps then will help
channel number should be 6
or reset the router
the hole is behind the router where you can see antenna
Posted on Mar 29, 2014
Did work now will not connect to WiFi
Try these steps.
  1. Unplug power to your cable modem
  2. Unplug power to your wifi router
  3. Shutdown PC/tablet
  4. Wait 2-3 minutes
  5. Plug power into modem and wait 1 minute
  6. Plug in wifi router, and wait 1 minute
  7. Startup PC/tablet
  8. Try reconnecting to wifi.
Jan 15, 2018 | Computers & Internet
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
Connect to bell modem
You can't.connect a modem to a tablet. You need to connect a WiFi router to your modem and connect your table to internet through wifi
Jun 23, 2014 | Proscan 8" Tablet with 4GB Memory
Unable to connect to wifi it just says scanning
make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
Android 4.0 Tablet PC
Feb 04, 2012 | Toshiba Thrive Android Tablet
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
I am unable to connect my Samsung monte s5620 with my bsnl teracom wifi modem. Although, I can connect it to my pc.
1.Verify the network key you have entered in the WIFI settings.
2. Check the Encryption type is TKIP.
3. Uncheck static IP in advanced settings.
4.Protocol must be set to HTTP in WIFI settings.
Nov 16, 2010 | Samsung S5620 Cell Phone
I cannot get wirelessconect to my laptop from my netgear modem router DG834G.I can see the signal but unable to connect
check whether the dhcp option is turned on in ur wireless router. if its turned off, change it to on state and try. u will be able to connect. still if u din get access. use some other lap to connect to ur wireless network. if it is possible to connect with someother lap, then the problem is with ur lap. the wifi drivers might get corrupted. re-install it to fix the problems. if all above doesn't gets work, then the problem is with ur wireless router.
Jul 21, 2010 | NetGear DG834G Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Difficulty in installation
1. hard reset ur modem ( it will set to bridge by default)
2. connect ur modem to WAN port at netgear router
3. connect ur pc to LAN port at netgear router
4. by default ur pc ip should be 192.168.1.x
5. type at IE/firefox address bar
username = admin
password = password
6. enter all basic info (ISP = other, streamyx username password, wifi setting)
7. set value for idle timeout (in minutes) = 0
Dec 18, 2008 | NetGear WGR614 Wireless Router
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computers & Internet Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
