Question about GE Nautilus 24" Built-in Dishwasher
Exterior door latch won,t close - GE Nautilus 24" Built-in Dishwasher
2 Suggested Answers
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Bmw 6 series doors are closed and latch is stuck
Buy something called a z-tool or call AAA and have them open the door for you.. A z tool took the place of a slim jim. It will not damage your car though...
Jan 25, 2014 | 2005 BMW 6 Series
Door won't open from inside '98 silverado
your door rod to your latch must have popped off your inside door latch. take your door pannel off and the door rood will be unhooked
Dec 12, 2012 | 1998 Chevrolet Chevrolet silverado
2008 GMC 2500 Cargo Van Dash keeps sayin lr door is open and it is not!!! Driving me crazy!!
the latch in the left rear door is either bad or stuck, open door, then with a screwdriver, rock latches in door to simulate closed. release with exterior handle. spray lubricant (WD40) into latches and continue to exercise the latch. if this quick fix does not work, then a new latch for this door may be needed.
DW Mylin
Nov 28, 2012 | 2008 GMC Savana
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
1999 Isuzu Trooper door won't open
those door latches use a very tense spring that engage the closing mechansim. If the handle lifts without any restiction at all,,the sping is missing...if the handle when pulled or lifted offers slight resistance,this means it is very weak and needs replaced. it does not have enough rigidity to release the lock works from the lock pin that is fixed to the inside door facing.
Jun 07, 2012 | 1999 Isuzu Trooper
Cab light and exterior bed lights stay on after closing the door , where is the door switch located. My manual is at home. F150 1998
The door latch switch is located in the door latch. If you spray the door latch with WD-40, open and close a few times, and spray again, it should start to work again.
http://www.f150online.com/galleries/images/4688-7633-119116.jpg
Jun 17, 2010 | 1998 Ford F150 Regular Cab
The exterior and intrior lights come on and go off
What I did was take a can of WD-40 with the straw on the nozzel and sprayed a large amount up into the latch mechanism. Do this to ALL the doors, hood, back door too. Open and close each of them many times to get the WD-40 all around the latch. The latch gets dust, dirt, old grease in it and needs to be lubed.
Hunnybunny11
Jan 19, 2010 | 2000 Ford Expedition
GE Nautilus 24" Built-in Dishwasher Logo
14 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
