Question about British Telecom Paragon 550 1-Line Corded Phone
Call light flashes all the time
Since caller display added
Caller ID is not displaying caller s number.....
ity is possible that the caller has blocked his number from being displayed
if other caller numbers are being displayed but not that one , that will be the case
if not reset the settings for caller id
Aug 13, 2016 | Emerson EM2646-WH Big Button Corded Phone...
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
My Model # is 27957FE 1-A Dont know how to reset
To set the time and date, start at the base unit. Then press the Flash/Program until Set Day appears on the display. Press the Review or Next button to select the day of the week. Then press Flash/Program again until SetTime appears in the display. Type in the time (hour (two digits) then minute (again two digits)) with the keypad number buttons. Then press Review or Next to select AM/PM. Press Flash/Program to store the information.
Please note that if you have Caller ID, the time and day transmitted with the caller ID information from your phone company will override the day and time you have set.
The manual is available here: http://www.home-electronics.net/USER-GUIDES/27957_DOM_ES_CL_IB.pdf . See page 15 for this.
I hope this helps.
Jun 01, 2011 | Thomson GE-28115FE1 Cordless Phone
Hi is there a way I can check caller id on my phone
That is a feature sold by your local telephone company. It cost a few bucks to have it added to your telephone line, then your phone has to have the ability to display caller ID. if your phone does not have that ability, then you can buy a display device that plugs into your line and displays it, It will only display those callers that do not block their lines from being IDed.
Jan 11, 2011 | Avaya Definity 6408D Corded Phone
No contact name displayed when receiving a phone call, only the #
go to menu,select call settings,then select caller id network and set it to 'automatic selection'.the phone will detect the network and name will be displayed.
Dec 05, 2009 | Sony Ericsson Satio Cell Phone
Lucent Partner 18D telephone turn on caller id
On one of those phones, press "feature 59" That will display the release of the processor. It might be that your processor is not CID capable.
Jun 04, 2009 | Lands Phones
Lost Manual. How to turn off "new call" light?
Try Googling (Northwestern Bell)(model)(manual) without parens to get instructions.
Aug 11, 2017 | Northwestern Bell Lands Phones
No ID caller displayed on the phone
Is the phone FCC approved for use in the US? Does the model purchased in Singapore use the same Caller ID algorithm as US phones? Have you tested a known good caller ID capable phone at your location to make absolutely sure the caller ID is actually turned on?
Mar 09, 2009 | Panasonic KX-TG5632 Phone
Indicator light on Alcatel 4039 Flashing orange
no problem it's just a missed call indicator... press it and on the display screen it will say missed internal or external call, press the button adjacent to that and it will display the caller id of the missed call... again press the adjacent button and you will be presented with the option to delete the missed call... as soon as you have the orange light will stop flashing. On a 4019 the sequence is Orange button, 5 times up arrow until the identity of the missed caller is displayed ok, ok again to delete and then back arrow 4 times... hope this helps :-)
May 25, 2008 | Alcatel One Touch FIRST 20 Cordless Phone
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
British Telecom Paragon 550 1-Line Corded Phone Logo
15 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
