Question about Mitsubishi CS-27609 27" TV
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
Our Mitsubishi Diamond Series CS-27609 has a problem when we watch it. The image looks "fisheye" as they say. The image is curved (convex) on both sides and we loose about an inch of the image. At the very tops and bottoms of the curves, there is an inch of big blank area, then the image picks up. The people on screen look all bendy and messed up. This looks most obvious when I am watching dports or TV Guide channel, because the bars and scores are curved, and half the time I can't tell if my Yankees are winning or not! How do solve this?
  • GoYankees Nov 11, 2007
    Reply? Anybody?
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Posted on Jul 13, 2009
Mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Jan 14, 2011 | Mitsubishi CS-27205 TV
I have the mitsubishi hdtv 65" diamond series with the blurry problem posted on 1/7/10. My model# ws-65711 has the same convergence problem. How can I fix this??
There are two convergence integrated circuits that have to be replaced. The center printed circuit board has to be removed to unsolder the chips. You might want to refer this to a local Mitsubishi servicer.
May 28, 2010 | Mitsubishi Diamond WD-65831 65" Projection...
I just purchased the Zeikos fisheye lense for my 50mm Nikkor lens and when I attach it, it doesn' take fisheye photos - just regular with some distortion around the edges... am I using this incorrectly?...
The 50 mm lens is a full frame lens, and the D80 is a DX camera. This means that the 50mm lens puts an image out that is bigger than what the D80 can "see". The good part of this is that the D80 (and most of the other Nikon DSLR's) use only the image from the center part of an older lens. The bad part is that if you put the fisheye filter on it, the fisheye effect that is mostly seen at the edges of the lens doesn't show up on the D80 sensor. If you could put the fisheye filter on a DX lens, it would give you the full effect.
Sep 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Mitsubishi CS-26201. Can't get clear image on screen
Hopefully you still have the remote.
On Remote, hold the Q.V. button down and press the number 9. That will bypass the lock
Then press the menu button on the remote - go to Advanced features, select Parental Lock - it should sho as on, hold the Q.V. button doown and press the 9 button again, and you will turn the lock off
Dec 31, 2008 | Mitsubishi CS-26201 TV
Colors off
I have the same problem, would like an answer.
Aug 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Televison & Video Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
