Question about Apple Cinema HD 30" LCD Monitor
30" apple cinema display suddenly went blank.
I have a 30" apple cinema display that suddenly went blank. It happened while I was looking at it. The power LED is on steady but the screen is totally dark. I tried it with a different power brick and different machines - same effect. Could someone please give any hints what to look at and maybe where to take it for repairs? Just wanted to mention that I have been using it for 6+ years in a dual monitor setup with an identical display and it went blank right while I was looking at it. Thanks.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Posted on Jun 14, 2014
4 Suggested Answers
SOURCE: Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Posted on Jul 20, 2009
Moozler
  • 3 Answers
SOURCE: Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Posted on Oct 27, 2009
  • 163 Answers
SOURCE: Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Posted on Feb 11, 2010
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Apple cinema display intermittent blank
I would suspect the screen saver function having a glitch in it.. I'm sure that you've wiggled, unhooked and re-hooked your display cable and made sure the connections were tight??? Look for the simple things first....
Oct 29, 2013 | Computers & Internet
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
Where to find replacement LCD for Cracked 30
You can try contacting Apple tech support
http://www.apple.com/support/contact/
They will be able to give you the best solution
Dec 17, 2009 | Apple Cinema HD 30" LCD Monitor
Cracked Apple Cinema 30"
Unfortunately, there's nothing you can do to remedy the problem, as I recall, you'd need to order the lcd paneling for the bezel itself (assuming the aluminum bezel is still fine), but be prepared to pay a rather hefty price. LCD panels are never cheap, at least if you order them direct for manufacturers or suppliers. You could try hunting around other websites that sell used parts, or if you happen to know someone that has an unuseable monitor but the LCD panel is still operational (just has to be the same part number and whatnot, unfortunately you can't just take any LCD panel and plop it in, in most cases). Hope this gives you a push in the right direction!
Jun 06, 2009 | Apple Cinema 20" LCD Monitor
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Startup issue
Sounds like a problem in the power supply section that will need component-level electronic troubleshooting. If it's under warranty and less than 30-60 days, I would suggest an exchange. If not, I would call the number in the manual for help.
Jan 01, 2007 | Apple Cinema HD 30" LCD Monitor
Apple Cinema HD 30" LCD Monitor Logo
123 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
