Question about Mitel 3300 Icp Range 3300 Ip Communications Platform
Block outgoing calls
On of my sites is having trouble getting a busy signal when they call Sprint customers. is this in my system or is it a telco issue
Why do I always get a busy signal?
I would try a different phone
Jan 27, 2016 | Lands Phones
Phone quit letting calls roll over to the next line.
Call TELCO that is their problem. That option is set up in the Central Telephone Office.
Aug 21, 2014 | Lands Phones
Blackberry
kerrybirch64
I would suggest to contact your telco ...
otherwise here is home page:
http://au.blackberry.com/support/smartphones/blackberry-curve-9300/os6.html
Aug 06, 2014 | RIM BlackBerry Curve 3G 9300 Cell Phone
Is there a way to block a specific phone number on Mitel Superset 4025?
Normally no. Your phone is part of a business telephone system. The system allows the sharing of incoming/outgoing telephone lines. If you need a specific phone number blocked, it will have to be blocked on these in/out lines. Unfortunately such lines are considered business class lines and you normally cannot block a specific number from calling you.
If you have trouble with a specific number, I believe you will have to contact the police before your carrier will be able to provide a block.
Apr 12, 2011 | Mitel Superset 4025 Corded Phone...
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
Landline is always busy
If its still showins as a busy when the phones plugged in at the NId ( the box outside) then the trouble is showing towards the telco . Call your local provider for repair.
Oct 09, 2009 | Lands Phones
When calling our office, customers get a busy signal
Your voicemail system is down. You have to locate the card in the system usually all the way to the right in the cabinet, and reset it with the little black dip switch on the front of it. push it down and wait 5 minutes than push it back up and wait for a green lcd on the upper part of the card. Or you lost your voicemail system programming. You may need tech support or a tech to come out. ldtsnj.com
Jul 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I have a callpilot 100/150 we acquired an add-on
First thing, the Call Pilot is your voicemail, not your telephone system. Your telephone system is most likely a Norstar CICs unit.
If the lines(trunks) are analog, it is the local telco provider that is handing out your caller ID.
Outgoing caller ID is not one of the features of the system for analog circuits. If you were running a PRI or BRI, then the system can hand out the caller ID. I would ask your telco provider to check the outgoing caller ID once again.
Jun 10, 2009 | NorStar CallPilot 100
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Jun 30, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
"Receiving Sleep" on Brother Fax 4100
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Sep 04, 2007 | Brother IntelliFAX 4100 Laser Fax
Mitel 3300 Icp Range 3300 Ip Communications Platform Logo
12 people viewed this question
Top Mitel Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Mitel Cell Phone Expert? Answer questions, earn points and help others
