F
Frederick Liewehr Posted on Feb 14, 2014
Burned resistors I need a schematic, or at least a parts list, for a Behringer BXR 1800 amp. R3 and R7 are burned up beyond recognition. Or, if you just know the values of R3 and R7, that would be great.
Denis Perkovi?
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Feb 14, 2014
Denis Perkovi?
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
13006
Points
30
HI try this link it mite help. :)
5 Related Answers
Anonymous
  • 682 Answers
  • Posted on Aug 03, 2008
SOURCE: Optronica amp one channel out.
disconnect any input cable and test-----------if you still have a problem connect your right speakers cables(which supposed to be good)instead of left speakers cable and test------ if the problem solved you will have a problem in left side(cables or speaker)-------if not solved you will have a problem in your amp it self. and needs hardware repair.
Anonymous
  • 4234 Answers
  • Posted on Aug 19, 2009
SOURCE: Need a PV 1.3K schematic...
As far as I know, these are not available directly on the web. Contact Peavey directly and ask for service parts. They will sell you the manual for $20 or so.
Dan
Anonymous
  • Posted on Dec 10, 2009
SOURCE: Acoustic Image Contra series II - No audio passing
I decided that without a schematic and parts list I shouldn't even attempt to repair it. I had taken the cover off and disconnected the control board from the amp. When putting it back together to return to owner, I noticed the plug and socket for the control board did not go together properly. After a little maneuvering, I managed to get then joined, and just like that the amp was working again. I suspect that who ever had repaired the ground on the guitar had opened the amp up as well, and just didn't get it back together properly. The amp wasn't really damaged, after all.
Anonymous
  • Posted on Mar 18, 2010
SOURCE: my Sansui amplifier AU-D607X got smoke,then when i
i hae same model of ur amp just explain wc part of the resistor got burned so i will have to look inside my amp....
Anonymous
  • 11896 Answers
  • Posted on Jun 10, 2010
SOURCE: I have a Kenwood Model K-88 Amp. The 2-resistors
Those are common parts. You can get them at partstore .com
Testimonial: "Yes I can get them, but I have to know the value of them first"
LG crt tv 21fs4rge-TS resistor R407 burnt i don't know the value
A burned out resistor means too much power has flowed and burned it out.
you need a schematic to find the resistor value but also what other parts have blown as I can guarantee just replacing the resistor would just mean another burned out resistor.
Red & green lines top and bottom and picture curve in at top and bottom
That all too common problem is the failure of the convergence amps in that unit which takes two STK392-040 Sanyo built Ics at board location Icz103 and Icz104 and usually one or more pico fuses and some low ohm resistors. F1018 sometimes opens due to stress but generally it's just the two 6.3 amp pico fuses and if they have opened I strongly recommend replacing them with a 6.3 amp slo-blo pico.
The low ohm resistors at RZ147, RZ146 usually show signs of heat stress and may even be burned beyond recognition. Testing at that point is almost unnecessary but will confirm their change in value. Almost always they need to be replaced.
Other than than that a good grade of solder and some heat sink compound and that's all the parts you need.. And to answer your initial question, yes about 40 bucks in parts.
Have a great day!
Bill
1helpful
Values of the resistors
Resistors R1, R2, R3, and R4 are arranged in a circuit as shown in the figure above. The direction of positive currents I1, I2, I3, and I4 through the resistors are shown. (i.e., negative current values correspond to currents in the opposite direction to that shown above). The values for the resistors and the batteries in the circuit are: R1 = 100 ?, R2 = 200 ?, R3 = 30 ?, R4 = 400 ?, V1 = 4 V, and V2 = 12 V.
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
A transistor or resistor burnt beyond recognition i need a wiring diagram to identify the type
You have not mentioned what electronic equipment you are requesting the details.
You will be able to confirm the transistor value from the stage where it has burned which also goes for the resistor. So take tech help than to try with trials to damage the set much further.
3helpful
Mitsubishi VCR HS-U57 power supply questions
The closest model I have is HS-U61 it may be the same
D901,902,903 and 904 -are part of a bridge rectifier -standard B+ diodes DSA3A1 - 264P430030
D913,D914-(connected directly to R902 through transformer winding to D914) -1SS82 standard switch diode
D917- (connected to base of Q903 and D916) 1S2076 standard switch diode.
Check if they are located as described.
Excessive brightness with retrace lines
Here are the values:
RY04 >>>> 68 ohms >>>> 1 Watt
RY04A >>> 47 ohms >>>> 0.5 watt
RY02A >>> 330 Ohms >>> 0.25 Watt.
All resistors should be 5% tolerance.
Curves in the top and bottom of screen.Picture image is discolored.
The convergence amps have most likely failed and taken with them the +/- 30v line. Your unit takes two STK392-040 Sanyo built Ics at board location Icz103 and Icz104 and usually one or more pico fuses and some low ohm resistors. F1018 sometimes opens due to stress but generally it's just the two 6.3 amp pico fuses and if they have opened I strongly recommend replacing them with a 6.3 amp slo-blo pico.
A quality shop will have this unit back on its feet in no time - faster if they have the parts in-stock, which you might ask about when you shop around for a good repair facility.
Have a great day!
Bill
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
