Question about Dryers
Kenmore dryer moisture sensor
It squeaks/squeals when turned on
Krazytech
  • 725 Answers
SOURCE: Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Posted on Aug 27, 2007
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Dryer Moisture Sensor
if you can get it to go back in sure why not,its simply a metal strip plugged in to a wire measuring resistance, so if its not physically broken you should be able to pop it back into place
Posted on May 12, 2008
  • 10865 Answers
SOURCE: Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
Dryer
Squealing could be a loose belt very seldom see this squeaking more than likely the drum rollers
Mar 22, 2014 | Kenmore Elite HE4 Electric Dryer
I have a kenmore gas dryer model 70722990 when you turn it on it has a very high pitch squeal sound runs for 5 minutes then turns it's self off and won't turn back on. can you please tell me whats going...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Kenmore Dryers
Model #970-c81032-20. Dryer makes high pitched squeal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 21, 2010 | Kenmore 83042 Electric Dryer
No clothes are getting stuck, but there's a rubbing and squealing noise
heatman101
sgfhwr
Jun 06, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.90802990 squealing dryer w/ black powdery deposit..
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 20, 2010 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
Jul 07, 2009 | Dryers
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Mar 07, 2009 | Kenmore Dryers
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
