Question about Sunbeam Twin Heated Blanket Navy Blue 006410-030-556
Control--Y85 Light flash & no damage to blanket
I have a sunbeam electric blanket and a code of f-2 keeps coming on. Is the blanket bad
1.) Follow the instructions on the flag tag attached to the control cord to reset control.
2.) Check the blanket/mattress pad for visual damage.
3.) If no visual damage is found, unplug the system from wall outlet.
4.) Check that the control is well-connected to the module.
5.) Plug the power cord into the wall outlet.
6.) Set the control to "On".
7.) If the system does not operate after 2 or 3 times trying to reset, disconnect the power cord and contact Sunbeam Consumer Care.
Nov 01, 2017 | Sunbeam Heating & Cooling
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
I bought a duel control blanket and the light just keeps flashing on high. is that the warming cycle?
You're asking about a blanket, even though you posted the question under a grill? What make and model blanket?
Oct 24, 2013 | Sunbeam SG7621SP Grill
The blanket doesn't heat. It's properly connected. The control box has two LEDs that keep on flashing regardless what I do with the wireless remote. I have two remotes, each one set for single side...
I think the board is burnt out on the unit and is in need of service or replacement through Sunbeam.
One can contact Sunbeam at 800-892-7684 for bedding.
Dec 18, 2010 | Health & Beauty
Red and green light flashing and wont work
PROBABLY A SHORT IN THE BANKET ITSELF AND IT SHUTS OFF TO PREVENT SHOCK OR FIRE.
Apr 27, 2009 | Washing Machines
Electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Dec 03, 2008 | Heating & Cooling
Electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Sep 20, 2008 | Heating & Cooling
Sunbeam Twin Heated Blanket Navy Blue 006410-030-556 Logo
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
