Question about Nokia 6230
Hard reset codes
Ear speaker and mic not work
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
How do i turn up the speaker volume not the ear piece volum but the "speaker" volume people say they can't hear me
you probally have a bad internal mic. on your phone most phone models that i have worked with dont have a volume control for the mic.
May 23, 2011 | Cell Phones
I'm not getting any sound out of my phone but only on the head set.When I make a call I can hear other people but they can't hear me.
You will need to do a hard reset on the phone to get the ear piece working again. I would advise saving all relevant data as this will erase all contacts and everything saved on the phone itself.
Go to your menu
Go to tools
Go to phone settings
Go to security
Enter your lock code (if you havent changed it since you purchased the phone, it is the last 4 digits of your number)
Select restore phone.
After the hard reset, you should be able to hear thru the handset. If unable to hear after doing a hard reset, then that means there is damage done to the handset ear speaker and you will have to have the phone replaced.
Hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | LG VX5500 Cell Phone
Earpiece not working
I have the same problem. By any chance have u fixed the problem since last year? Do you remember what you did?
May 19, 2009 | Apple iPhone 3G
Nforce4 sli edition audio pins
No I dont. Check the mother board manual or try trail and error
Aug 14, 2008 | Intel Motherboard
Sollution
My friend you have a solution for motorola c168 ear not working but speaker is ok. any solution pls send me. my email address abdurrazzak30@yahoo.com.
thank you.
Jul 07, 2008 | Motorola Mobility C168 Cellular Phone
No sound on my calls on j600
When you make call no body can hear you because there will be mic in your handset it might be in loose contact or the mic is damaged ...
and you cannot hear them because the ear piece speaker is also in loose contact or it is damaged ...
if you are good at opening the handset then just open it and just have a check is there any miscontact in both the mic & the ear piece speaker ...
i think the mic and ear piece speaker are not touching to the circuit board so as it is not in contact you are facing this problem ..
check for the miscontact and solve it ... if they are damaged then replace with the new ones..
while purchasing the new ear piece & mic buy which is compatible to your handset model ..
if you are not good in opening then just visit the technician ...
he will do it ...
The price of the ear piece speaker & the mic are very cheap ...
if you visit the technician then he may take the service charges extra ...
any doubts reply me
i am always here to assist you
thank you
bye ..
May 11, 2008 | Samsung SGH-E900 Cellular Phone
Speaker Failure
jamin is not silent.
jamin can vibrate but wont ring.
music works fine only if though a headset.
calls work fine only if through a headset.
was working fine playing music and then we tried to make a call after pulling out the headset and got no audio and as it was expecting a headset it wasnt picking anything up from the mic. maybe its a mic issue? ie mic died so jamin switches to headset? just thought of that so will investigate.
Nov 27, 2007 | i-mate JAMin Smartphone
Nokia 6230 Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
