Question about COOPER CAM-LOK G361 One Size Professional Ultra-Flex Gel Kneepads
Replacement straps for cam lok kneepads - COOPER CAM-LOK G361 One Size Professional Ultra-Flex Gel Kneepads
Quik lok stereo vol pedal crackles
spray the controll with cleaner. if it dosen't work replace the controll
Jul 16, 2011 | Quik-Lok Quik Lok VP-26 U Sustain Pedals
The passenger side, front door won't open with the key, remote, buttons inside nor can you force the lock open inside. What should I do
sounds like u have a froze up door lok motor.thats wat they do wen they freeze up/lock up..u need to remove door panel an manually force the lok lever to free it up, in order to open door an replace lok motor. good luck
May 01, 2011 | 2000 Buick Century
Milwaulkee sawzall quick release wont release.Cam turns ok but pin is holding blade.Tried prying blade out w/vise grips-no luck
try using WD-40 first to loosen up pin and if not you might have to replace the quick lock assembly. ot a tough job about 10 minutes or less.
Jan 17, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
The easiest way to remove a fuel pump off a camaro
Drive the rear of the Camaro onto a set of ramps and secure the parking brake. If the Camaro no longer runs due to the fuel pump, place the rear end of the vehicle onto jack stands.
Use a socket and ratchet to disconnect the negative battery cable from the negative battery terminal. This removes power from the electric fuel pump.
Place a jack under the gas tank and raise the jack so it butts up against the tank. This applies pressure to the tank and prevents it from falling while you remove the retaining bolts for the tank straps.
Use a socket and ratchet to remove the retaining bolt from each of the two straps located closest to the rear of the vehicle. These are the rear strap bolts. Pull the straps down.
Lower the jack to lower the tank from the vehicle. Because you left the front of the straps attached, the tank rests at an angle under the vehicle. This prevents the need to unhook all of the hoses connected to the tank.
Place the cam tool (J-24187) onto the retaining cam on the top of the tank and turn it a quarter turn counterclockwise. Take the sending unit cam off the tank.
Disconnect the fuel pump from the sending unit cam and plug the new pump into the sending unit.
Place the fuel sending unit cam onto the tank and turn it clockwise a quarter turn with the specialized tool.
Use the straps, bolts, socket and ratchet to jack the tank back up under the Camaro and secure it.
Use the socket and ratchet to reconnect the negative battery cable to the negative battery terminal.
I hope the above helps.
Good luck.
Dec 03, 2010 | 1995 Chevrolet Camaro
I have 6020 nokia mobile, and i inserted the pin code code incorrect more than one time. now he ask me to enter the puk code. what is the puk code and where i can find it??
Bhosdina navra betha phone ma ghoda na marta hov to, ghel choida, chodu madan choksi. phone lok karvo hoi to keyguard ma lok marai, nakar apdi gand ma lok marai... have maravo gand lok vagar.
Oct 22, 2010 | Cell Phones
Engine strap and wheels STARLET 98
By engine strap do you mean Cam belt? Which should be done every 100000kms or 60000miles tyres should be replaced when the tread gets below 3mm deep ( depending on your country's regulations ).
Try abebooks.com for the manual.
Hope this helps.
Apr 14, 2010 | 1984 Toyota Starlet
When do you need to change the cam strap
If by cam strap you mean the Timing Belt. This belt is usually replaced every 60-100K depending on the manufacturer. Check your owners manual or call your local dealer to find out what the interval is exactly on your car. If you have a timing Chain, then the interval is usually much longer.
Oct 06, 2009 | 2004 Kia Optima
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
The refrigerator door swings open without resistance and hits the counter behind the door
Hi, Check the hinge cam and closer kit on the bottom hinge. See if there are any cracks or even part of the cam mising. They have a tendency to wear sown through the years. If this loks like the problem, please let me know and I can get you part #'s for you.
Vid
May 23, 2009 | Refrigerators
COOPER CAM-LOK G361 One Size Professional Ultra-Flex Gel Kneepads Logo
485 people viewed this question
Top COOPER CAM-LOK Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a COOPER CAM-LOK Craft and Hobby Expert? Answer questions, earn points and help others
