Question about Cameras
My panasonic NA-F130gs machine machine spins slowly
4 Suggested Answers
SOURCE: washing machine
Please check if the drain solenoid is functioning. This may caused the problem.
chris
Posted on Mar 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
some1cares_m
  • 5323 Answers
SOURCE: Washer rocking while on spin.. Panasonic inverter from load washing machine model no NA 14VA1
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Posted on Apr 13, 2015
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
My panasonic waching machine model is NA F80B2 Error is U 11 U 14
See http://www.manualslib.com/manual/783539/Panasonic-Na-F78b2.html?page=13#manual
Feb 06, 2015 | Washing Machines
Loud wheezing noise on spin cycle
you need to unblock the pipe work from the tub to the pump ,,then the pump,, and the pipe from the pump to the drain
Jan 12, 2014 | Panasonic Washing Machines
I have a Panasonic NA-148VG3 with a Coin stuck in drain pipe before filter
Just found a coin stuck in the filter! Thanks for your advice John C :)
Oct 19, 2012 | Washing Machines
How to do manual setting for Panasonic Washer NA-F701GS
I keep program to normal, water level 51 and wash,rinse & spin but half way the washing machine go to reserve button (9 hrs).
how do i cancel the reserve button?
Nov 28, 2010 | Panasonic Washing Machines
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing machine
something caught in pump or bottom drum hose,check filter also!!
Mar 19, 2008 | Washing Machines
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
