Question about Dyson DC33 Bagged Upright Vacuum
Clean top filter
Can't get the top filter out to wash
  • Les Dickinson
    Les Dickinson Feb 14, 2014
    Hi Ann gray, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    New Friend:
    Problem Solver:
  • 15 Answers
This is how to get the filter out for washing
http://www.youtube.com/watch?v=IC6UMuMeNyg
Posted on Feb 26, 2014
My Dyson DC35 stops after the first minute. Then it keeps stopping every few seconds. I checked for obstructions, washed the filter and cleaned the brush. Is it the batterie?
In the inlet pipe, there is a small valve that can get jammed shut with debris this causes them to pulse start, stop, start, stop, and so on. Ensure this is floating free, not jammed shut, it works purely on gravity... The other possibility is the cyclone needs cleaning. Remove the filter and check no dirt is lodged there. Remove the top torx screws and keep them safe. Carefully remove the top check for damaged seals gaskets etc (this can cause a malfunction). Again keep safe. The cyclone can then be inspected for dirt and dust clogging holes and airways. Clean thoroughly and reassemble, make sure all components are dry if they have been washed to clean them. Hopefully, this will restore the machine to working order
Feb 09, 2018 | Dyson Vacuums
My cordless Dyson V6 animal vacuum filter smells badly, like dog breathe, how do i rid the smell?
I had a similar problem with a smelly filter, even after multiple washings and finally discovered an actual solution, which I can’t believe Dyson won’t tell you. Those filters that slide out of the top can be disassembled by removing the outer fabric from the plastic frame. When I did that, I found a massive clump of debris inside that would never have come out just by rinsing it under a faucet. Perhaps they don’t want you to know this, but it’s a two minute fix and actually addresses the source of the odor, rather than just covering it up.
Jun 30, 2016 | Dyson Vacuums
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Cleaning my vacuum
There are two filters that are washable. One is in the top of the dust bin and the other is in the ball assembly.
Sep 03, 2013 | Dyson DC25 Vacuum
How do i wash my filter on my dc08?
There are 2 filters on your dc08 the one that is under the bin is sold as being lifetime which I strongly disagree with. I work as a vacuum Technician and I would strongly encourage you to buy a new exhaust filter every 2 years. The filter at the top of the machine can be washed in normal tap water. The filter is in two pieces, the blue sponge part can just be squeezed like a kitchen sponge the other part with the colored plastic casing can be gently scrubbed with a toothbrush or similar. It is important to remember that the more often you wash the sponge part the less often you will need to was the cage. If you need to buy a new Dyson washable filter because yours won't come clean they are only $20 so just visit NelsonVacuums or VacuumSpot and have one delivered.
Feb 11, 2011 | Dyson DC08 Hepa Allergy Bagless Canister...
Hair on top of washable filter
your animals are shedding.if you have pets then you will have to clean the filters more often depending on how much their shedding.its probably a good idea to clean the filters after each use if your getting that much hair.you might want to turn the vacuum over and clean the brush roller and the underside because the static electricity from the hair will cause it to cling to the under carriage
Apr 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
I want to know how remove the filter to clean or replace on my fm744h fantom vacuum
The hepta filter has a place on each side to push in.The top
comes off and the filter is inside.The new one is about 24.00.
Remember to clean the dust filter .This is located in a chamber
below the cannister . Remove the cannister and there is a grey plastic tab,it will comes up and dust filter is right there-pinch
it and it will peal out.It can be hand washed and air dried.
Parts at TotalVac.com
Nov 28, 2008 | Fantom Vacums FM744H Vacuum
Dyson DC33 Bagged Upright Vacuum Logo
37 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
