Question about Fujitsu Heating & Cooling
Green timer light keeps flashing after resetting fujitsu air conditioner model AST9LSBCW
I have done everything that the manual said to do, including ensuring time is correct and then followed instruction on how to cancel the timer but it keeps flashing and only warm air is coming out. I have checked power board and no fuses have been blown.
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
  • 86 Answers
SOURCE: Airconditioner doesn't switch on, it keeps on flashing green LEDs
replace remote by new one.cirkit problem
Posted on Mar 17, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
The green operation light keeps blinking. I've reset unit and it still blinks
Could u explain more about this error,how many led light,flashing ??? Brand???model???
May 08, 2015 | Fujitsu HALCYON ASU24CL1 Wall Mounted Mini...
Fujitsu asta24jcc timer 2 green flashes
The indoor unit has the problem and it's the air thermistor. You need to replace it.
Jan 01, 2014 | Heating & Cooling
Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Jun 20, 2012 | Fujitsu Heating & Cooling
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
